Duetz allis 2.30 round baler
Kurt WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Topic: Duetz allis 2.30 round baler
    Posted: 02 Dec 2011 at 12:21pm
Local auction tommorow has a 2.30 round baler.  I was wondering if they reliable units, what it would be worth and what to look for on a round baler.  Also wondering what size of bale it would make.  I need a smaller bale so my 3410 gehl skid would move em.  Thanks Kurt
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2011 at 1:23pm
Kurt, is that one of them soft core balers that has rollers and no belts for bale forming? Darrel
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2011 at 3:03pm
        My neighbor had one and he likes it. His made a 4by 4 bale. If it sat outside for a while the trip to tie the bale on his got all rusted up and we had to clean it up good. After that it worked great.
                                               John Carlson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2011 at 3:12pm
Yes Darrel it is a roller model no belts.  So what are the advantages to all rollers and not the belts?
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2011 at 3:43pm
We have a friend that has a Claas with rollers.  He says that his bales aren't as dense as a baler with belts.  I know he has had bearings go out on his from time to time but his has seen quite a few bales in it's lifetime.  I'm not sure how many you are planning on baling per year but I'd say if you are only doing a few hundred and it goes cheap it would be a good buy.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2011 at 4:43pm
The roller type are much better for corn stalks and bean stubble, if you plan on baling any of that. They eat the belts up in a hurry.
strollinnolan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote strollinnolan Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2011 at 5:14pm
I have a gehl 1310 which makes a 4X4 bale like the deutz baler.  Deutz baler has more rollers than mine.  Make sure it has the auto lube to oil all the chains.  This is a must otherwise you will be spending alot of money on metric chain and sprockets.  It makes a soft core bale but you can make them almost as dence as a belt baler if you slow down a bit twards the end of the bale and really pack it in there.  Once your tractor starts to really grunt you know you  have a nice bale.  I would not hesitate to buy one. Very simple to bale with, almost no weaving required.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2011 at 6:54pm
They take a lot of more hp than a belt or chain baler. It was all our 175 wanted toward the end of the bale with my uncle's DA. They don't stack very well or weather outside as well solid core bale. The tailgate hinges are the weak spot. They can be broken very easy if you let the tailgate down on the bale you just ejected. They don't eject the bale like a belt baler so they have a kicker on the back. I've never seen one that the kicker worked so you have to back up to dump the bales.
With all that being said, they are pretty trouble free and can be had cheap. I know where there is a good DA baler for sale right now for $500.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 7:58am
with the soft core baler, you are limited to making only one size bale, which may, or may not be an issue, Depends on your situation. When you finish a field, and only have a half a bale in the chamber, you basically have a half bale of loose hay. With the soft core baler, you can bale hay slightly wetter, and the bale will cure out to make for some very nice hay, especially alfalfa. By having rollers instead of belts, you eliminate belt splice trouble, which can be an issue when belts get age on them. On our place, we use mostly the new holland 660 hard core balers, but have a caseIH 8480 softcore baler around for some occasions where it just works better, like baling cornstalks this fall. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 4:52pm
Thanks guys for your input!!  Went and stood in the rain all day to find out that the owner bought it and now is going thru a divorce and never used it.  He said he didnt even know if it worked, so it brought $750 and I just couldnt buy it.  I went up to 700 to take the chance but i didnt know if it was worth it just not knowing nothing about round balers in the first place.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 6:23pm
Ahh, the joy of auctions.
This page was generated in 0.213 seconds.
