185 temperature questions
briarpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote briarpatch Quote  Post ReplyReply Direct Link To This Post Topic: 185 temperature questions
    Posted: 02 Dec 2011 at 5:33am
I just replaced the temperature gauge on my 185 and got a reading at the left edge of the white region.  Question: does anyone know a proper test for the temperature sending unit?  Most likely, the thermostat is stuck open as this tractor has essentially been in barn storage for over 3 years.  I would like to eliminate the sending unit as the culprit before changing the thermostat.  I get 1.5 to 3 ohms resistance across the sending unit depending on temp; I have seen references to resistances in the 400 ohm range for AC sending units.  Any suggestions?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2011 at 7:40am
It should vary by temp, but not a mere few ohms.  I just looked at a random one and it varied several thousand ohms with a temperature span of 100(C) degrees.  It almost looks as it your sensor is shorted.  Pull the wire at the sensor and substitute a resistor.  Try 1000 ohms.  Try another value - perhaps 5000 ohms.  If you get readings somewhere in the gauge, replace the sensor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote briarpatch Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 4:37am
Doug is right.  A new temperature sending unit will read from 100 ohms (very hot) up to 800+ ohms (very cold).  Checking the electric sending unit will pretty well tell you if the gauge is getting a proper signal or else the thermostat is stuck.  Thanks for your data!
This page was generated in 0.049 seconds.
