anybody pull a stock WC?
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: anybody pull a stock WC?
    Posted: 01 Dec 2011 at 5:03pm
Could you tell me what kind of expeiances you have had? What type of classes, wts, outcomes. What are you pulling against? Thanks,JM.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 5:12pm
I've pulled our WC wide front a few times in 3500 stock and can usually come out in first place.  Also pulled our WF unstyled quite a few time and usually can do pretty good.  Usually pull in 2nd gear, because usually power out in first gear.  Usually had to add 3-400 lbs to get around 3500 lbs.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 11:38pm
my 1940 wc is far from stock.i did start out stock,but installed rebuilt e-gleaner engine.much more fun.a wd-45 crank in that wc engine will really bring it to life,good luck!
