removing copper injector gaskets/seals
Brad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(WI) Quote  Post ReplyReply Direct Link To This Post Topic: removing copper injector gaskets/seals
    Posted: 01 Dec 2011 at 4:53pm
I removed the injectors in my 7045.  2 of the copper seals came out with the injectors.  4 left in head.  I tried a bent wire, too weak.  I ground the edge of a screwdriver to a hook, and removed one.  It was pretty stuck, the rest are pretty stubborn.  I have never had this problem before, maybe I have been lucky.  Any tricks to try, or just keep at it?  I wasn't paying attn to which seals came out with injectors, so I have to try to look in hole to see copper.
Jeff B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff B Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 5:32pm
You need allis chalmers special tool # 91658 It is a long bolt that will screw in the inside of the washer. I can't think of the size off hand, either a 9/16 or 5/8. try it on one you have out to find the size, Thats all I've used for years.
ncrc5315 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ncrc5315 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 8:17pm
Take a 5/8" bolt, grind the end so it has a bit of a point. Put the bolt into the injector hole, turn the bolt in until you feel it grab the copper washer, and pull it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 9:46pm
Use a 5/8 fine thread tap. Screw it into copper gasket and pull it out.  MACK
This page was generated in 0.031 seconds.
