D 17 SIV diesel HELP!
Doyle B(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Topic: D 17 SIV diesel HELP!
    Posted: 30 Nov 2011 at 6:54pm
I have a d17 s IV diesel that is building up alot of pressure in the coolant system. I just had the radiatior recored about 2 months ago and i left the thermostat out. However it some how builds up pressure and keeps poping the cap. We tried different caps nothing. Before i bought the tractor it had a head gasket replaced is it possible someone plugged one of the coolent ports. Im stuck any in put much appreciated.
           Thanks, Doyle
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 7:00pm
You have a cracked head or blown head gasket. Wish I could give you better news......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 7:12pm
Ditto on the leaking head/gasket. The real bad news is there is a good chance that the sleeves have dropped in the block. Pull the head and check the sleeve stand out. The specs on the original blue prints say flush + or - .002. Experienced A-C dealer mechs say + .002 which I agree with. Measure your sleeves when you get the head off. If they've dropped in the block, just well plan on an overhaul.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 7:14pm
I should add that just putting a new gasket on the dropped sleeves won't hold long...
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 9:54pm
I hate to add to any bad news but if the sleeves are at spec be sure wipe them clean and check for cracks, this is very rare but when I worked at an implement dealer one of the other mechanics just rebuilt an engine that soon after started pumping water out the overflow. We ended up finding a crack liner. I'm not firmilar with the Buda engine as to weather the sleeves are wet or dry.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 5:35am
so it probably is not good bto keep runnng this tractor?
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 5:51am
You can re-cut the shoulder in the block and add a shim to get your sleeve up above. AC had a tool that did the job with a in-frame block, although out-of-frame would be ideal.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 9:43am
We ran a WD45 diesel for a couple of years like that...just kept the radiator cap loose.  It wasn't our main tractor and just got intermittent use.
ALLIS EXPRESS!
This year:
D-allis Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 9:48am
We had that happen to a D-19 diesel and it was a cracked head.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 12:27pm
How long has the head gasket been in the tractor?   Did they put the right 1 in?  Mine got the wrong 1 put in and wound up costing me a complete overhaul.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 4:11pm
If i loosen the radiator cap would it be okay to snowblow with this winter or no. I really need this tractor as for the 190xt block cracked and the 5040 injector pump pooped out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2011 at 5:39pm
Depends on how much air is being pushed into the cooling system. I have a leaky head gasket that pushes air at idle. I just don't run it at low idle. At higher rpms, say above 1000, it will fire and pass on to low pressure on that cyl. and does not affect the cooling then. If you are pushing air at operating rpms then you'll push so much air into the head that it will not cool and then will surely crack the head.
