A2 combine hydraulic pump
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: A2 combine hydraulic pump
    Posted: 30 Nov 2011 at 5:46pm
anyone have any idea what the flow rate on the Hyd pump from an A2 combine is.. wanting to use it for another project as the combine is scrapped.
thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 9:27pm
Depends on what rpm you want to run it. A2,f,f2,late K,g all used the same pump with different GPM but drove pump different rpms.  A2 was around 10 GPM.  MACK
This page was generated in 0.048 seconds.
