706 b
Doyle B(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Topic: 706 b
    Posted: 29 Nov 2011 at 5:38am
does any one know what engine is in the 706b forklift
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 11:39am
According to a August 1977 AC 706B operators manual the following 2 engines were available;
Ford gasoline 192 cu in 4 cylinder 3.1L 56hp, 7:1 compression ratio
Perkins diesel 4.203 203 cu in 3.3L 4 cylinder 50hp, 17.4:1 compression ratio
Both engines spec, 2400-2550diesel 2500-2650gas rpm rated speeds, 12V electrics, negative ground, 8 quarts of oil, 16qts coolant.  706b has 20 gal fuel tank & 30 gal hydraulic system.
Now, if you have an AC 706b like mine it has been retrofitted with another engine?  Mine has a continental 4 cylinder f227 gas engine.  It is under powered by my standards.  I hope to swap an AC 433T or AC 226 d17 gas into it soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doyle B(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 4:26pm
Thanks for all the help. As far as i know it has the original gas engine in it. By any chance do you know what ford engine was put in it or just that it was 192cu in 3.1L
Thanks , Doyle
This page was generated in 0.328 seconds.
