tyres for allis b |
Post Reply ![]() |
keithm ![]() Bronze Level ![]() Joined: 03 Jul 2011 Location: AUSTRAILIA Points: 25 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Nov 2011 at 1:48am |
i have just about finshed the rebuild of my high crop be
and now iam in need of ruber i need the size of the rears and the frounts
i have a set of 19.5x24 0n the rear and there are 3inch spacers under the spindles on the front with 13inch rims
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6465 |
My B has 11.2x24's on the rear and 4:00x15's on the front. 10:00 was the original number but was replaced by 11.2. You will probably need new rear rims if you go to 11.2's from the 19.5's. I would like to see a picture of the 19.5's on your B.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87710 |
maybe a misprint ? I cant see 19.5 inch tires on 24 inch rims ! For a HYCROP i would think you want 28 or 32 inch rear rims. You should have the original 4 x 15 inch tires in front. If you put 3 inch blocks in the front and you want to maintain level, then you need 6 inch bigger rims in the back. So you can go with 28 inch rims with big tires like 12.4 wide, or use the larger rims 32 inch, with a narrow tire like the 9.5 to keep it somewhat level.
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
Asparagus special was 8 X 38 and potato special was 7 X 28.
keith, have you got adaptor plates (spokes) to put the bigger rims on the original cast hubs ?
this tractor came to me as a big box of bits the rims came with it may be i should look for a set of rims
24 are too small if its a hicrop or cane tractor
wrong tractor, right idea
Post Reply ![]() |
