Hydraulics and power-steering
Gil (cent MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gil (cent MO) Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulics and power-steering
    Posted: 23 Nov 2009 at 8:24pm
Has anyone on this forum attempted to use a Char-Lynn torque generator along with the existing tractor hydraulics for power steering? I am aware of how the WD and the wd45 hydraulics operate and the pressures involved. I see where the latest Steiner catalog lists a "power steering priority flow control valve" which will operate under pressures which can be adjusted. The valve is set to operate at 1500 PSI from the factory but can be adjusted to other applications. I am thinking that this combination would work as long as the foot clutch is engaged on the WD and the 45 and would work even better on any total live power machines.
Any thoughts on this?
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 10:20pm
Gil; I am very pleased with the live charlyn power steering that Jack (KY) recently added to my D-14.  The power steering pump (and oil reservoir from a Datsun pickup) is driven by a second V-belt pulley secured to the origional crankshaft pulley that drives the generator (12V).  Jack also added a female spline to this "two pulley crankshaft assembly" and fabricated a 16" long shaft with male spline on one end and 2-bolt butterfly on other end for bolting to the hydraulic pump mounted on the loader. This 16" long shaft assembly slips into position prior to installing the loader and thus provides live hdraulics for the loader.  It is removed with one hand after removing the loader.
This post does not address your question, perhaps I should have created a new topic in describing my D-14's hydraulics,
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 10:48pm
New generation JD tractors use the main hydraulic pump for power steering, power brakes, and a hydraulic differential lock. But their main pump is rated at 20 to 24 gpm depending on the model and vintage. Is it not true that the WD pump is only rated at 3 or 4 gpm so there might not be enough flow to run the power steering and do any other work.
Gerald J.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 6:06am
I have nice small PS pump out of Isuzu truck that would be ideal for pressure to torque gen. I am looking into pulling steering box apart also to see if it is adaptable to actually becoming the torque gen also. Anyone want to take the parts for messing with?
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 6:22am
The WD hydraulics does not have enough flow to operate the power steering. There would be nothing left for the lift.
skipwetle NWIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwetle NWIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 1:00pm
the hydralics on a WD/WD45 are closed center, Im sure the Char-Lynn torque generator is an open center valve.   I dont think it will work very well if at all.  HTH
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 5:00pm
what would happen if a guy would pull, the steering system out of a old combine and use it in place of a manaul steering system. Have a Ford 400 with loader, that has a bad steering box. thought I could use the tractors hydroulic system to power it
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
This page was generated in 1.305 seconds.
