8070 fwa ps
BStone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Topic: 8070 fwa ps
    Posted: 26 Nov 2011 at 3:39pm
Having trouble with my trans temp light.Can it be replaced with a gage?Has anyone done this?
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 9:42pm
what kind of trouble?? does it stay on? flicker on and off? might not be a big deal to fix the light.i havent done this but i cant see what it would hurt to run a gauge.some others may know more than me on this but i would try to get it working the way it should...jmo...Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 10:06pm
I would check wireing first. Check plug in at sender connections between sinder and light. MACK
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 10:34pm
I suppose you could screw in any automotive-type temperature sender that fits. The sender and the gauge would need to match, of course. Once the gauge is installed, would you know the high  transmission temperature limits?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 10:25am
    Light stays on as soon as you crank the tractor.Theres no way the temp could be hot when its 35 degrees and you first start the tractor...checked the wiring I could get to and everything seems ok..Trans.has given no problems...no leaks or anything...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 10:32am
Disconnect the wire from the sender/switch at the transmission.  Do not let the end of the wire short to the frame.  If the light stays off, the problem is the transmission temperature switch.  If the light stays on, follow the wiring back to the light.  Look for chafed insulation and the wire rubbing at that point.  I would say the most likely culprit will be the temperature switch.
