Fuel tank webbing WD45
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: Fuel tank webbing WD45
    Posted: 25 Nov 2011 at 6:05pm
I am putting my tractor back together and am wondering if the joint in the tank webbing should go under the tank?
thanks
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 8:34pm
   The strap should be on top of the hood and the tank under the hood. Back edge of strap should be even with back edge of hood. If that is what your asking ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 9:13pm
thanks, but I purchased the mesh/fabric material that goes under and top of the tank and I am not sure how it is best put on.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 10:33am
Webbing goes between the tank and saddle mount under the tank. Hood goes on top of tank metal to metal with no webbing.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 11:23am
I glued a thin strip of webbibg to the underside of the hood where it meets the gas tank and it works well. You can't see it either. It's really only necessary under the tank though.
Wink
I am a Russian Bot
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 3:49pm
There are two pieces of webbing strips, a wide one for under the tank, and a narrower strip that goes all the way across the top and sides of the tank right under the hood about where the metal strap holds it down.  The hood shouldn't have any ability to touch the tank.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 6:51pm
There is a packing strip listed in the WD parts book. Shown under the hood between the hood and gas tank.
Wink
I am a Russian Bot
