Non high pressure cylinders on a 45
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Non high pressure cylinders on a 45
    Posted: 23 Nov 2011 at 8:52pm
Have a Freeman Loader I want to put on my WD45, cylinders aren't high pressure. Rated at 2000 PSI. Is there some type of pressure relief valve I can put on the 45 to drain the access fluid back to the pump? or a pressure gauge I can install and just keep an eye on it? I likely won't be lifting the max load on the tractor, more like leveling gravel and moving cinder blocks, maybe moving snow in the winter, etc. The loader will usually be off the tractor, and just put it on when I need it. I'd like to someday install a shut off so I can run the 3pt and loader separate if needed.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 8:55pm
I don't know how the 45 will like it but if you use an external open center control valve pack for the loader it will include a pressure relief valve that discharges to the return. I think you will find the 45 also has a low volume system that will make the low pressure loader run slowly.
Gerald J.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 9:02pm
As Gerald said, Low pressure cylinders are going to be awfully slow on the 45. I would consider using a PTO pump or go with some high pressure cylinders.
I think I may have a couple of high pressure cylinders lying around. I had a old AC loader that the frame is junk. I think the cylinders are still there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 9:08pm
The cost to ship would almost be enough to justify me buying brand new ones
German Shepherd dad
#WD234847
#WD88193
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 9:48pm
I think I have a valve that was used on a WD that reduced the pressure so that a regular cylinder can be used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 6:32am
Local hydraulic shop wanted MORE money to repair ONE cylinder on my D-14 Freeman loader than what it was going to cost to have TWO custom made cylinders AND all the hoses from PrincessAuto( Cdn mini version of NorthernTool/ Harbour Fright)!
Nether got my money , sold the loader as I didn't use it for 2 years.
My option though would be to put a separate pump on, 3 spool valve (up/down,tilt bucket,' something else' option).
Having it split like this, keeps tractor original...allows 'other' things to be added to the lower pressure system easily.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 7:03am
Buy newer 100 series tractor w/loader, WD45 can stay original, and stay in better shape that way.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 7:07am
Besides being high pressure the allis system is low volume,as Gerald already said, however I think I would give it a try, if not satisfied you can then buy pto pump or smaller cylinders I have a friend with a setup like that and he gets by.
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 4:13pm
I'VE GOT LOW PRESSURE CYCLS ON MY WD45 LOADER . IT.S A LITTLE SLOWER , BUT LIFTS LIKE CRAzY. WILL LIFT THE REAR OF TRACTOR OFF THE GROUND. IT SURE HELPS WHEN BIG BALES ARE FROZE DOWN.
