1975? Allis-Chalmers 712H
Seth Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Topic: 1975? Allis-Chalmers 712H
    Posted: 22 Nov 2011 at 9:42pm
I have a Allis Chalmers 712H its in great shape and only needs a battery charge or work on the carboratior how much is it worth? Oh and it has the rar pod lights on it which are REALLY hard to find thanks. :)
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 8:19am
Why you want to sell it to some one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 9:29am
No im just curios although my friend offerd $350 for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 9:30am
OH WAIT! that is you josh haha make a bigger offer and will talk ;)
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 10:07am
That's not an unreasonable offer for a garden tractor that doesn't run.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 10:10am
i was out looking at it  runs if it gets a battery charge and its in better shape then most 60s-70s tractors iv seen. i would post pics if i new how.
There are no atheist in foxholes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 11:11am
Those Simplicity/A-C units were well built and I have no problem getting anything I need from Sandy Lake. I picked up an 816GT (79 model as I recall) about five years ago for 350.00; carb rebuild, new muffler and battery and that 16hp B&S would put some grass through that 48" deck. Had to treat the motor as the rings were likely stuck but she came around after sitting in inside storage for over 15 years. If the 716H does not have grease zirks on the spindle assemblies like the 816GT, you can likely get them from Brenda at Sandy Lake also as I upgraded mine to same last summer.
I also picked up another complete 816GT unit off OK Craig's List (300.00) a few months ago and this one is extremely tight compared to the first one I found. No steering play and sound tranny/diff but the deck has sealed spindles that seem to growl a bit at times.
Motor is tight and power compared to my first unit is very noticable and she fired right off with jumper cables on a very old battery and fresh gas. Warm-up, dropped all fluids and re-filled engine oil and "Seafoamed" both the crankcase/fuel tank and this one has no visible smoke which is rare with the big twin Brigg's of that era. Put an in-lne fuel filter and shut-off valve on it if you buy it as you will be glad you did.
First unit will likely get a Honda re-power, if that old Briggs ever finally gives up.
Second unit will hopefully become a traveller as I will make a small two seat trailer/sulky to pull behind her when I go to shows, taking the deck off for potential spare use someday.
Will also be putting D-Series seats on both at some point.
As long as I can keep an old unit like these running cheaply with good maint. and a few spare parts, I can't bring myself to fork over big bucks for one of the new ones as they just are not built like the older ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 1:04pm
its not mines to by i own it do you know if the value increses since it has the rare pod lights? I heard that a 712H with pod lights is has rare as a modle G.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 1:34pm
Well I paid I think $265 for this 716H with "pod" headlights this summer on eBay.  Gave it the same carb cleaning & double Seafoam engine treatment Tim mentioned, fixed/adjusted a few minor items and it runs great.  Will need a new battery for next season and the deck could use a little patching.   Those outside "pod" headlights were at least an option on all these 71x tractors and could be installed later or swapped from a parts tractor.  I have at least a couple spare sets of them from a large batch of used Allis/Simplicity parts I bought someone out for a whole price of $50.   HTH with your valuation...  Mike
P.S.  This tractor is now OFF the front porch at the farm and under the carport behind the 65 Lincoln...
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 3:34pm
looks just like mines but mines out side parts are in a lot better shape and i have a diffrents shape of seat on it and i took the belly mower off of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 3:37pm
I've seen it, and it is in very nice shape.
I need a AC mower to replace our green thing.;)
Edited by Josh Day - 23 Nov 2011 at 3:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 3:44pm
totaly josh
