Fuel Trailers
Spud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spud Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Trailers
    Posted: 19 Nov 2011 at 8:50pm
Has anybody here owned or used a fuel trailer?  I am thinking of a 500-750 gallon sized unit.  What are the dot and hazmat regulations on them?  Do you need courses and endorsements?
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 8:56pm
We use a old trailer sprayer with the tank and boom removed and the tank is replaced with a propane tank in it's place.  Stay off the main roads and you should be good to go.
Spud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spud Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 9:03pm
I would be using it to haul diesel around the oilfield in North Dakota and would want to be on the up and up due to insurance and liability reasons.  Not sure if the paperwork will make it unrealistic though.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 10:08pm
For carrying that much hazardous material, you would have to follow the DOT regulations.  You would need to have training and get recertified every few years.  On the road, the load would have to be correctly placarded and you would have to carry transportation documents in the truck with you.  If you use something that has a smaller capacity, you can be exempt from the regulations.
Dealing with Hazmat is my day job.  I deal with this stuff almost every day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 10:59pm
You would be dealing with a cargo tank , Yes you would need placards on it and probably testing done on the tank to certify it along with a few more rules and regs. You would need a fire extinguisher also and protected valves and hatches .
 Has Mat endorsement, copy of Has mat book within reach when exiting cab, and may need shipping papers.  Any tank over 110 Gallons becomes a problem. the pickup box tanks that were 120 gallon have fallen out of favor and a smaller portable tank is now found in or on most sites or vehicles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 11:04pm
Might look at some of the construction auctions and see if a field service truck for heavy equipment comes up . Some outfits use a truck body with fuel and lube tanks along with took storage and such as part of their fleets. Also a home delivery type fuel oil truck single axle unit with hose reel and meeter, should be some of them around. They would be set for bulk loading and have the proper fixtures for filling and vent recovery on them.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 1:41am
i'd just buy an old fuel truck, straight truck, they hold that much, and already set up with pumps and valves and meters, gotta be alot less regs on them than ona trailer rig!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 8:27am
Regs have changed over the last few years as to vapor recovery, no spill connections, special brake application safeties and such, check on the regs before you buy something that needs to be retro fitted before you can use it.  There are also inspection clauses that have come about that if it has not been hydro tested they may not allow fuel to be put in it, a lot of cash to spend to get to fully legal.
Spud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spud Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 9:30am
What if I park it in a central location and have it filled by a bulk truck then bring the equipment to the trailer?  If I move it empty or with under the 110 gallons, do I still need to do all the paperwork and endorsements?
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 11:27am
Probably, they go more by the size of the tank than what's in them. You just might overfill it to full and then?????  That's their thinking and probably true 90% of the time, unfortunately!
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 12:04pm
Are you looking at a commercially built unit? The local CNH dealer is selling them and it would meet the DOT / Hazmat requirements. I don't know if training or certifications would be required to pull one here in IL. I doubt you would need any if you were under CDL required weight, as when pulled with a 1/2 or 3/4 ton truck.
They are pretty nice looking units, compact tandem axle trailer with stainless steel covers, should last a long time but it wouldn't be cheap.
I'm sure they have sold a few to some of the big time operations with multi - thousands of acres that get far away from home before it's all harvested and tilled.
Spud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spud Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 12:23pm
I would get a commercial built unit that was built to code.  Just trying to figure out if I want the extra headaches that come with one of these units.  I fill out enough paperwork now.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 1:41pm
I read somewhere that there is talk about some rule changes or exemptions being proposed because the large combines and tractors hold in excess of a 100 gallons in just one vehicle. So you need to transport 100s of gallons just to fuel the fleet for the day. Just another thing going along with the ever increasing size of things. You  would have to current on the the most recent rules.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 2:08pm
You wouldn't need a CDL for a 100 gallon tank.  I think the rule is a CDL with tank endorsement for a tank of 300 gallons or more.  That might be 1000 gallons or more, I don't remember.  If you carry fuel and your vehicle is placarded, you would need a CDL with HAZMAT endorsement.  I'd have to look up how many pounds of gasoline or diesel you can carry without needing a placard and I don't have the info in front of me.  I'm pretty  sure you can get by without any additional licenses when you have a 100 gallon tank.
Edit:
The HAZMAT endorsement is nasty.  It's the hardest exam of the endorsements.  Here in Oregon you need a "security clearance" to get one also.  It's an extra $50 and a background investigation.  For $50 it has to be a simple computer check.  Nothing like the 5 month long check they did on me in the military when I got my SCI.
Edited by DougS - 20 Nov 2011 at 2:13pm
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 4:31pm
In Ne if trailer is used for farm husbandry and is not licensed dot regs don't apply. But U R still responsible for any spill. You need to have SMV signage and keep under 25mph. I put this together for under 4k and works great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 6:45pm
Spud,
Talk to the people selling the commercial built units they should know what your local laws are.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 8:25pm
You won't have to follow the hazmat regs as long as you move it empty on public roads. If you could, the best thing would be to fill it up and leave it off-road while there is fuel in it. You could then have a 100gal tank on your truck to carry it to the equipment or bring the equipment to the big tank to be filled.
