GLEANER K QUESTION
Chad B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad B Quote  Post ReplyReply Direct Link To This Post Topic: GLEANER K QUESTION
    Posted: 15 Nov 2011 at 8:06pm
Dose anyone know how many bushel per hour you could expect to harvest with a K model combine with a 2 row corn head and also how many bushel of wheat per hour with 13' grain head?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 8:39pm
In corn I'd expect four hoppers per hour if you have it set properly.
daughter#1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daughter#1 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 10:16pm
according to an allis crop saving guide for the k it will do .8 acres per hour with a 2-38 corn head and .9 acres per hour width 3-30 corn head. With a 13' grain head it will do 1.6 acres per hour they also say that an f with a 4-30 corn head at 90% efficiency at 2.5 mph will do 3 acres per hour, 21.6 acres in 8 hours, and in 20 days will harvest 432 acres
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2011 at 3:31am
i was running my "K" in dry corn with a 3-row head, dad had his IH 403 with a 4-row head, and i could stay ahead of him! i had to dump more often as the grain tank was quite a bit smaller!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad B Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2011 at 9:16pm
ok that answered my question......thanks
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 8:16am
daughter- could you post the same for an m2? thanks if you can!
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2011 at 10:40am
Daughter#1, I have a similar Crop Saving Guide booklet from 1976 - maybe its the same?  Its information is interesting by today's standards.  I wonder how they would classify the harvest days per month available by todays weather??  2009's harvest season?
I wanted to add that it lists acres per hour(aph) for Acres combined per hour @ 1mph.  So, if the K is set properly and picking reasonably standing corn, it should be able to do 2.5 mph.  At 2.5mph, the 0.8aph becomes 2.0  & 0.9aph becomes 2.25.  Im thinking those figures are theoretical.  In 1976, a K2 330 should have been able to harvest 22.5 acres of corn in 10 hours unloading on the go with very long passes.  At 130 bu/a, thats 2925 bushels or 32.5 graintank loads @ 90bu/k2 graintank or 3.2 loads per hour like DrAllis stated.  Today, a k2 330 harvesting 200 bu/a corn would equate 4500bushels or 50 graintank loads @ 90bu/K2 graintank.  The K without graintank extensions carries 66 bushel.  In 1976, the 130bu/a total of 2925 bushels/10 hours ~ 45 loads or 4.5 loads per hour.  A K in 200 bu/a corn ~ 70 graintank loads....  The book specs unload time for a K2 @96bushel graintank is 84 seconds.
Clint- this Crop Saving Guide booklet was produced for the K2-F2 combine.  But, it does show bigger corn head capacities Acres combined per hour @ 1mph as follows:
238 0.8
330 0.9
430 1.2
438 1.6
630 1.8
830 2.4
This page was generated in 0.234 seconds.
