D14
cowboy656 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowboy656 Quote  Post ReplyReply Direct Link To This Post Topic: D14
    Posted: 11 Nov 2011 at 9:13pm
I was just wondering, did Allis make a loader for the D14?
The one I bought has a REX loader on it with many welds and repairs.
Thanks Jim
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2011 at 9:45pm
The were at least two series of Allis loaders shown in Norm Swinford book.
When the D14 came out they modified the farm loader or trip bucket type to fit it and called it the Model 14.   It was a simple design made with round tubing.
The 400 series with double acting cylinders and hydraulic bucket came out later and would have been matched to the d15 but still would fit.   I think they had to have a separate hydrualic pump and circuit running for the 'low pressure' high volume required.
Also many other loader makers were established and they quickly would have made models to fit the D14. Some were even endorsed by AC as approved attachments for the construction markets.
Edited by Rick of HopeIN - 12 Nov 2011 at 7:11am
John Sealey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Sealey Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 4:57am
Yes Jim I have a D14 and it has a trip bucket loader. It has been painted over put you can read made for allis chalmers. Can't remember the rest. I was thinking of adding a front pump and converting it to full hydraulic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 7:25am
I had my book out this morning and edited my previous reply with more info.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 9:56am
I have an Allis model 14 loader available that came with my 1959 D14.  It has all of the mountings so it is easy to bolt on the tractor.  It has a mechanical trip bucket.  I have it for sale if you are interested.  I have not had any interest in it so far.  If it does not sell, it will go to the scrap man.  I have a couple of buckets for it too.
CarsonD14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CarsonD14 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 3:17pm
I'd love to have a loader like that for my D14, but Ontario is a long haul from Kansas City, Missouri!
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowboy656 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 6:29pm
The only problem I can see with the tube lader, I have a front mounted pump. I don't know if its high or low pressure, how do I tell? Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 7:33pm
You have the high pressure system like a WD. The low pressure system didn't show up until the series 4 D17. Not sure if the D15 ever had the low pressure system, the D14 didn't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowboy656 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 7:56pm
Thanks for the info on high/low pressure. How much are you asking for the loader. Jim
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 8:07pm
Those loaders were made by freeman for Allis chalmers
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2011 at 9:38pm
Allis also had a model 40 for the D-14. It's not a pipe type but is flat welded steel plate like an industrial loader but mine is a trip bucket. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowboy656 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 11:09am
To the guy that wanted pic's he mail me at jimsjoynt@hotmail.com it keeps telling my file are to large. Jim
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 12:09pm
A little welding a trip bucket could be made into a hydraulic dump.
The tractors with the Hi volumn/low psi syste, I do believe had the pump drive off the front of the crank. I think with a little work a guy could build a pump to go in the belt pulley drive. The D15 and D17 (except series IV) had this as add on/optional equipment. It would be dead power with the foot clutch, but if a guy had a scrap belt pulley and some time with a lathe I think a mount could be built.
1968 D15D,1962 D19D
