my first tractor
dillpics View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillpics Quote  Post ReplyReply Direct Link To This Post Topic: my first tractor
    Posted: 10 Nov 2011 at 3:30pm
             I just got a 1949 c and its my first tractor.i picked it up for 450 and i think it was a good deal. the engine is locked up but over all the tractor is in pretty good shape. i would like to do a total restoration to this tractor and add hyd and put a 3 point hitch on. I would like to know if there is anything that i should just go over and check as normal things while i try to get it running. i would like to get it in working condition befor i tear it all apart for restoration. i also wanted to make it 12 volt. thanks for any help and like i said its my first tractor so im sure i have alot to learn.
        thanks again dillon
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 4:13pm
Rather than take the time with all of the snake oil remedies to unstick an engine, just take the head off and take a look. You will know in 30 minutes what you are up against.
Good luck and come back often, this is the best place on the www to get AC advice.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 4:19pm
As John said. I have been there many times myself and never have I been sorry I didn't at least remove the head and pan.  You are indeed taking the right path in getting it running before sprucing up and painting. Good luck
chevytaHOE5674 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevytaHOE5674 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 4:26pm
Sort of depends how stuck it is. I've freed up more than a few motors with a little ATF/Acetone mix down the plug holes and then letting it soak for a few days. Then putting the hand crank on it and giving it a little tug and away they go.
Also had some that required pulling the head and pan and unsticking them that way.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 4:56pm
Freeing an engine is one thing, but rings are another story. It's a good way to end up with a oil burner, too. I'd at least pull the head and pan as stated above also....sounds to me like you aready know the steps you want to follow to do it right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 5:04pm
I vote for head removal too. One of the good points on a C is it's one of the most inexpensive tractors to work on. Engine parts are readily available new. Pretty much anything else you'll find on evilbay or some of the guys here. They were also designed so the guy who was a better farmer than mechanic could do most of his own repair work. This is also the best place to ask, "How do I..."
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 5:06pm
I'll add that a decent set of sockets and combination wrenches will get 95% + of what you need to do to get it running.
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2011 at 2:25am
A lot of good advice on the engine, now for something that is just as important as getting it moving-- stopping it. I don't think I have ever seen (and I know I haven't operated) an old tractor that had halfway decent brakes.
I think most people used them until the brakes quit working, then used the "drop the implement and step on the clutch if its an emergency" method. I hate running into things when I am on a tractor.
Robert
rvraaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rvraaz Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2011 at 8:38pm
Congrats on your first tractor. My first is a 1947 model c. Good luck and have fun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillpics Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 9:17am
i got all the pistons out and one connecting rod is bent. since im gonna restore this tractor and im already this far should i just go ahead and replace bearings and gaskits and then its done and over with? let me know what you think. when you rebuild one of these engines do you normally take everything to get checked at a mechine shop? thanks for any help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillpics Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 9:19am
where should i go to get parts because i know im gonna need more than a few. is there a brand better then the rest or a shop that is the place to buy from?
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2011 at 11:28am
Hiya, where in PA are you at? I'm right around State college and if you're close enough I could give you some help. Just finishing up my CA so we're in a similar ball game.
Some advice I would give you right now is while you are working on the engine, start spraying stuff down with penetrant. Saves you time waiting later. I don't know what "rust" condition its in, but I know with me that's what I did while I was working on something else. You said about converting it over to 12 volt. Are you planning on putting more lights on it or do you just prefer to have the 12 volt?
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2011 at 1:24pm
I do not know of anyplace that is a good yard around you. Bud Yuegling's in Gettysburg was at one time. Your best bet might be to stick with vendors on this site, and have the stuff shipped. Good to see lots of you young guys down there in central PA.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2011 at 1:30pm
my first tractor....a brand new AC 7010 diesel back in 1980 (rented tractors before buying this one) still have it, still use it all the time, only things replaced/fixed...valve cover gasket, a new turbo, and an o-ring in the PTO, and one new PTO external shaft i broke this year! other that that oil/tires/batteries...oh yeah...1 new starter syninoid.  however ya spell it)
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2011 at 2:02pm
We have a lot of the C's in salvage.  Can help with just about any part you need and happy to walk you through the process.
JimD
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillpics Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2011 at 3:21pm
thank you everone for offering your help! i live in elizabethtown pa but im willing to take the drive to you if your willing to take time to give me your knowledge and advice. pm me with your contact info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillpics Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2011 at 3:35pm
im 25 so i guess im young i have always been around farms but have never owned any farm equipment and bairly operated any.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillpics Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 10:51am
well i think i have found my second ac and if it looks as good as it sounds i will be picking up a b next week to add to my collection and it is also locked up and comes with a woods belly mower.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2011 at 8:17pm
Now you've done it! Just one is a hobby. Two is the start of an addiction. I now have 2 Cs(one is more of a parts tractor) of my own, 2 Bs(one of those is also more of an organ donor), and my grandads C down here trying to rehab/restore it. Also bought a B112 garden tractor with a mower and rototiller that came completely disassembled on 2 pallets. I don't buy anything that isn't stuck, worn completely out, badly broken, or torn into a million pieces. Just love a challenge(or maybe i'm just cheap.LOL!)
Anyhow, a B with a Woods mower is a great little unit if you have a lot of grass to mow. The later Bs had the same engines as the C. Engine serial number is on the carb side of engine, on the bellhousing flange. Will start with BExxxx or CExxxx and end with a G(for gasoline) or a K(for kerosene/distillate ). If the engine in your B has a CE series engine, it is 125 CI and the same as the C. Kerosene engines have lower compression pistons. If you happen to have one of these, and don't plan on restoring it back to "correct"(ie, running kerosene in it), gasoline pistons, rings, etc would work fine. Of course, you can get some different quality/performance levels in that, but there are plenty of good sources that advertise on here. They will gladly help you to find out what you want and lead you in the right direction to get it done as properly and inexpensively as possible.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 8:00am
Where are the pictures?
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2011 at 3:01pm
Hey Dillpics, I sent you a PM!!!
Finally another LOCAL Allis guy!!! If you EVER need any help let me know. I sent you a PM and included some information about Alvin Martin, he'll get you fixed up with everything you need for parts and is a great guy to talk to.
I'm in Witmer/Bird-in-Hand/Leola area and have 2 B's myself with a full compliment of implements, if you ever need any assistence or anything else please let me know! I'll try and help out as much as I can.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillpics Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 10:01am
i will post some pics of the c. i think the sale of the b is not goingto heppen because he has not got back to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillpics Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 2:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 2:10pm
Why did you run over the original seat and hand lifts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillpics Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 2:16pm
they were off the tractor when i got it and i put them under the tractor when i pushed it there. trust me i did not run over anything i had to push it my self! can i ask what the hand lifts are for?
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 2:25pm
Looks Good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 12:04am
Looks like you got a pretty straight one dillon. It's always interesting when you start into them to see how much prep work the person before you did before it was painted
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 8:58am
Looks like handlift and rockshaft for 1 bottom plow, but it looks like you might be missing some pieces.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillpics Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 11:03am
the only prep work they did was shake the can befor they sprayed. trust me they sprayed over anything that was on the paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dillpics Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 11:04am
if anyone wants the hand lift they can have it because i have no use for it but do not want to scrap it if someone can use the parts!
