WD45 hydraulic fluid
jhid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhid Quote  Post ReplyReply Direct Link To This Post Topic: WD45 hydraulic fluid
    Posted: 08 Nov 2011 at 6:22pm
what do you guys run you your WD45 hydraulics? I checked mine this afternoon and it's not even appearing on the dipstick with the cylenders extended
red and green are nice for christmas, but orange is all year round
http://www.canadianantiquetractor.com/tractorforum/
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2011 at 6:29pm
I run 10-30 engine oil in mine.  Dad has 821 hy-tran in his.  Both get along fine.
AaronSEIA
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2011 at 6:33pm
If you se engine oil be sure it's sure it's non-detergent.
Dusty
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2011 at 6:33pm
My seal between the hyd and trans has been shot for years. I run transmission/hydraulic fluid in both compartments and let it mix. No problems in 20 years.
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2011 at 6:41pm
I switched over to hy-trans in everything but the finals.
james6600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote james6600 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2011 at 7:03pm
       79fordblake how do you keep the hy-trans from absorbing moisture? I use to run it in every thing but come spring it always looked like milk, do you have the same problem?
Central WI AC guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Central WI AC guy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2011 at 7:34pm
I thought the cylinders should be collapsed when checking oil level?
jhid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhid Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2011 at 8:28pm
mine said cylinders extended on the dipstick
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2011 at 8:43pm
Do you park your tractor indoors? I have found that no matter how tight you think you've got it sealed up, water will get in it sitting outside in the rain. I've never heard of hy-trans absorbing moisture out of the air any worse than any other oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote james6600 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 9:46am
     79ford my IH560 is the worst at absorbing moisture but it is parked in an old bank barn basement an it is high in moisture down there, my IH175c crawler is parked outside it does it too but very mildly it is also used a couple times a week year round where the 560 is only used 5 or 6 times a year. My Allis's do it mildly too but my Ford 6600 that is used all summer is pretty bad at moisture also. Other than price I really like the oil, noticeably lower temps and better wet clutch and brake function, I could live with the high price if I didn't have to change it so often. A year or so ago I was on an IH forum, they were discussing the same problem and a person claimed that the oil was designed to absorb moisture and if left in an open container it would pull moisture from the air. I thought about running a moisture canister on the 560 to see if that helped (the one that look like there full of kitty litter and change color as they absorb). I have been switching away from it but just know I am increasing wear by doing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 11:46am
Hmmmm no I don't have that problem at all.....tractor is always inside...not really sure how you are collecting all that moisture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 3:14pm
Yeah,read the fine print on the dipstick.An extra quart won't hurt if doing lots of loader work. Used 10-30,15-40 and now hy-tran.All work.
