917 hydro fluid
mark glenzer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark glenzer Quote  Post ReplyReply Direct Link To This Post Topic: 917 hydro fluid
    Posted: 07 Nov 2011 at 1:46pm
I just purchased a 917, about 1985 model, anyone know the proper oil for the transmission and how to check it ?
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 1:49pm
Some use hy-trans hydraulic oil and some use ATF. You can use either but I would drain it since you just got it and refill with your preference.
Edited by D-17_Dave - 07 Nov 2011 at 1:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 1:51pm
most of the small hydro units use either 10/30 or 20/50 engine oil .
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark glenzer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 3:19pm
thank you for your reply, I guess I will change it and the filter, do you know if the hid lift runs off the same fluid from the transmission or is there a separate pump
