Time to cut the fat......
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: Time to cut the fat......
    Posted: 06 Nov 2011 at 9:29pm
Ok so there is one big pull left locally and its indoor....classes start at 3000lbs and go up....I wanna cut the fat on my 45 WC. I see the obvious things. Take off the deluxe seat and go to a solid mount, remove the cultivator lift, rear wheel weights, factory air cleaner assembly....anyone see anything easily removable? Locally at Fair pulls I do terrible with the pro sleds they run but my I'm told I can do ok down there so I figure I'll give it a try.....Here are some pics of what I'm working with.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2011 at 9:31pm
Oh and I'm not sure what weight I can get down to and I'm around 330lbs myself which I know needs figured in. I do know I'll be running either 3 or 5mph pace classes.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2011 at 9:37pm
Put those rear weights just ahead of the axle and get rid of a couple of the front weights. Make a drawbar a little longer and rely on the downward pull of the chain to the sled for shifting that weight toward the back. We had a WC puller who ran nothing but center-mounted weights and did rather well. His engine had too much power and he obviously had a '45 crank on his motor. That had nothing to do with his traction, though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2011 at 9:41pm
The Drawbar is actually back as far as it can be by local rules but I have to get the hitch height for this pull coming up....I may get rid of the clevis and use a junk snap coupler drawbar backwards....use the snap coupler eyelet as my hook point. I'm running a stock 201 right now with a D17 Gov spring....I'd love to put a Gleaner E or something in it for now till I have the money to build the engine I want.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2011 at 10:08pm
If you build a bracket to mount those rear weights ahead of the axle, build it in such a way that you can easily move the weights forward or rearward. There's a point where there is a balance.  In theory you shouldn't need any weights in front. Positioning is a trial and error thing, of course.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2011 at 11:14pm
Lights, fenders, pto gearbox, lighter race battery, lower fuel level, aluminum parts,etc. High gears in the tranny and milling metal off heavy parts like the flywheel and such will add up. Just how bad do you want to win is the answer to the question......
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 1:00am
put yer ole lady....oooops...i mean YOUR loving wife on there to pull!
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 5:15am
Make your weight brackets out of aluminum, lose the fenders, fender brackets/brake covers.  I made some out of 10g metal just don't have a parking brake, lights, generator, and the stuff you said.  If you get serious, get some pressed steel wheels, worn tires (there is alot of weight on those tires you have there).  i am also a big believer of putting the weight out as far as you can in front.  If your club follows like the national guys you can be 11ft from center of rear axle to front of the weights.  I like the drawbar as high as possible and as much weight on the nose as I can get.  If I pull the 5500 or 6500, I LOAD the belly bar full, then mix front a back.  I run 15.5's on mine with light wheels and all the un-needed stuff off of it and I can get it in a 3000# class with a 75# IH on the nose
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 5:41am
Sure wish they would have some light classes around here. They want to start at 5000 or 5500. Are they scared???
"Burgie"
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 7:42am
benny....   sounds like you're going to harrisburg in a couple of weeks.  i would like to go with my wc, but its the first day of bear season and i'm going bear hunting....i expect to go to the farm show pull in january.  good luck.   alan
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 8:15am
Alan, maybe I asked before but you wouldn't happen to have a D17D that pulled at the farm show last year would ya? was a nice running and looking tractor! -Wes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 10:48am
Burgie, i think they area scared of you in the bikini!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 11:40am
wes
no, that wasn't me.  i didn't pull last year, only watched.  and my wc is very ugly, but like i say, paint doesn't pull!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 1:17pm
Hell Larry, that would even scare me and I ain`t scared of nothing!!!!!!!
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2011 at 9:27pm
Thats where I'm headed. Anyone pull there have any tips or suggestions?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2011 at 8:59am
If you're running a stock 201 with a mag, (i can't tell from your picture) you could take the generator, starter, battery lights and wiring off and save some weight. Of sourse you would have to crank start it, but a 201 isn't hard to start if it is right.
Robert
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2011 at 8:08pm
Benny i plan on goin to farm show in january for the pull. i am taking my narrow front 17 and my uncles wide front 17  mine is stock but my uncle is building an engine as we speak.  just might meet up with some of the ppl from here.
    Shawn
190XT,D17and 7045
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2011 at 6:07am
See if you can find some 14.9x38 Firestone Field & Road tires. They always worked well. Put those doughnut spares from a car on for front rubber too.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2011 at 6:37am
Alan,
Sometimes you bite the bear, sometimes the bear bites you! Be careful there buddy. I'm sure there's more Tractors that we need to make road trips on.  lol!  Have fun at the cabin!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2011 at 11:35am
I dont want to run 38's...at least not yet. With stock WC high gearing and a stock 201 it'll kill me in pace class. I'd like a set of 14.9 or 16.9 28's or even go those size's in a 30. Anyone have any?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
This page was generated in 0.227 seconds.
