ac 7000 fuel pump
jtaub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtaub Quote  Post ReplyReply Direct Link To This Post Topic: ac 7000 fuel pump
    Posted: 04 Nov 2011 at 7:27am
Neeeding help on how to turn the fuel up slightly on a 7000, i'm not looking to totally hot rod it just a little extra, thanks
If it doesn't fit, get a bigger hammer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 8:09am
Just behind the top cover  is a screw that sets at a 45 degree angle to the top. Remove plastic cover, loosen lock nut and back screw out 1/4 turn at a time.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtaub Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 9:03am
thanks, we've had this tractor for years, just thought it'd be nice to see if just a little more from it would help at times, thanks again
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 11:16am
That's the HP (max fuel flow) screw, right?  Isn't there also another one that limits the maximum amount of fuel per a plunger stroke or something like that (referred to as the torque screw, I'm guessing as it really pours some fuel to the tractor at the lower rpms)?  I could've sworn there were two different screws on a RoosaMaster pump that controlled fuel flow.
Hurst
1979 Allis Chalmers 7000
5800 Hours
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 12:16pm
the external screw is the torque screw. It affects mostly rated speed fuel output. The actual fuel adjustment is inside, on the leaf spring(s), roller dimension. This is what actually determines pump output. You can back out the torque screw for more hp only if the roller dimension is set high enough. may gain 10-20hp. It will not lug as well when pulled below rated speed though, less torque rise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 8:22pm
Injpumped is right, won't be alot of HP but if it is a 4 roller pump don't adjust leaf springs unless you take the pump apart and measure each set of rollers. A 2 roller can be adjusted from out side with no problem.  MACK
This page was generated in 0.159 seconds.
