What model is this 2 bottom AC Plow?
grskal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grskal Quote  Post ReplyReply Direct Link To This Post Topic: What model is this 2 bottom AC Plow?
    Posted: 03 Nov 2011 at 11:44pm
The number on the back of the moldboard is 372-16. Trying to find out the right model #. Trying to find another landslide.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 12:27am
Plow bottoms were sold separately from plow frames. 372-16 probably is an aftermarket moldboard, AC 372 bottom.
Plow frame is not adjustable width so its not a 70 family or an 80 family, but has trip shanks which were standard on an 80 but optional for a 60. With 2 bottoms that makes it a #62 plow with trip shanks and #372 bottoms. My plow frame books says that type of spring trip shank was effective January 1965.
For the later plow bottom, my plow bottoms book shows 4 bolt hole shares 337848, and with five bolt holes 344190, and 344866 for right hand 16" bottoms.
I don't have any.
Gerald J.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 12:30am
   It has a #62 frame with #80 series trip stub beams so it is some what of a combination of parts.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 12:40am
   Gerald where are you seeing the trips were optional on the #60 series frame, I can't find it in my book ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote grskal Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 6:33am
Thanks for the Info. That will help my search for the landslide a lot easier. Just to clarify Gerald, the moldboards were not after market. Maybe the moldboard will help me figure out what the moldel or part # of the trip bottom is. The label on the back of the moldboard is Allis Chalmers. Unfortunately that was the only label on the plow that was ledgible. I will post another picture this weekend some time of the landslide I need. The picture I have takes up more memory allowed on this site so I will have to take a smaller one. I've seen you have lots of experience with Allis Gerald, so hopefully we can figure something out more about my late father's plow.
Edited by grskal - 04 Nov 2011 at 6:35am
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 9:42am
Just for your information, the hinge pins on the lift links are supposed to be underneath the cross-shaft and not above as shown in the photo.  It will help give you more clearance when the plow is raised.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 10:48am
TramwayGuy, you are right on the lift links. I had them wrong and Jim Lux showed me the write way. I could not figure out why the plow did not lift any higher, when we fixed it, it went a lot higher. Jim also showed me that the links them selves were shoved on the tractor lift arms farther than I thought they were supposed to go. The lift link bolts should not be screwed into the holes on the lift arms of my 50 WD, but you shove them on the lift arms farther and there is kind of grove on the lift arms that the bolt screws into. I also use a safety chain underneath where it goes into the snap coupler, that is in case it would ever come out accidently, it would hopefully hold the plow from coming up on me in the seat.
Pastor Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 12:13pm
My plow bottoms book shows only a short landside specific to the 372 bottom. Part number 338006. Shorter than the frog. Though on page 136 it shows a Medium Landside for 370 and 387, cast type number 343854. On page 138 there's a steel type for the same bottoms that bolts on with the 9/16" plow bolt that holds the frog to the shank. Probably takes a longer bolt that is listed on that page. Next page another option for the same plow bottoms, 346305 held with two 9/16" bolts, one a plow bolt the other a hex head capscrew. Page 146 shows a couple styles of landside braces, plow bottoms not specified. Page 147 shows long and medium landsides for 360 and 370 bottoms. These are made up of steel plates and heels. Heel 333540, 338448 (too long for plows with a rear wheel). The side wear plates could be 333457 for medium length, or 339740 in hardened steel. Another optional slip heel is a casting 331070.
Next page long and medium landsides for 370 bottoms, medium cast plate 341827, long plate (takes a 341838 brace) 341839.
A landside for a 387 is probably still made by Weiss plow. Landsides were more varied and rarely specific to the plow bottom. And generally mounted with the same two 9/16" bolts that all bottoms use to mount the frog to the shank.
The optional spring trip stub for the 60 frame is shown on pages 227-8 in my form D-5 Plow Frames parts book dated 7-68. Its easily overlooked, I did for years.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grskal Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 4:42pm
Thanks TramwayGuy,
I was wondering if something was wrong there.
Gerald, I think you are right about the landslide. The landslide is short on my dad's plow. Roughly 10 inches and it doesn't have a support bracket to the moldboard. Thanks for the help and vast plow knowledge!
Edited by grskal - 04 Nov 2011 at 4:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 6:25pm
   Thanks Gerald. Still learning the book.
   According to Swinford's book the 62 and 63 came out in 1955. The 70 series was available in 1956 because of the lack of trash clearance on the 50 and 60 series. The 80 series with trip bottoms was not available until 1960. The 80 series did not replace the 70 series in order for the farmer to have a choice of shear bolt or trip beam protection. I may be assuming here but I would think the 50 and 60 series would have been discontinued in favor of the 70 and 80 series. I would venture to say these trip beams were mounted on this 60 series sometime during it's life and are not original.
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 6:40pm
you run the lift link on top for laying off a land on the first pass.that way your plow runs level when not in a forrow then flip it over after you lay off a land
Post Options Post Options   Thanks (0) Thanks(0)   Quote grskal Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 8:09pm
Thanks Corlew, That makes perfect sence. Learning a lot on this site.
Thanks Rfdeere, I searched for images on google and I saw a 80 series and they had identical bottoms. So I believe you were right that someone added those on sometime between the 60s to the early 80s, because my dad had this plow for long as I can remember.
Edited by grskal - 04 Nov 2011 at 8:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 9:12pm
That page says the spring trip shanks for the 60 were effective in January 1965. Best I can gather from the drawings the rigid shank of the 60 and 70 use the same bolt holes as the spring trip shank for the 60 and 80 so they could be retrofitted. I haven't looked at plow frame part numbers but I suspect all the plow frames had bent bars in common and I know the hitch parts for three point, pulled behind, and snap coupler are listed separately from the frames so they could be swapped out and had to be specified in the order. Probably they were options on the plow frame specification, e.g. you ordered a #62 plow frame with snap coupler hitch. Then you ordered plow bottoms, and coulters specifying the size of landside with the plow bottom or ordered as separate item. And you had a choice of several forms of coulter that often was not specific to a plow frame, but gave different costs and longevity in the coulter bearings, the pivots, and the blade survival when hitting rocks. Some flexed, some didn't.
Reiterating what I see for plow frame variations. 50 has vertical shanks and fixed width. 60 has angled generally fixed (not spring trip) shanks and fixed width (except for one 10-12). 70 has angled fixed shanks and adjustable width for two sizes of bottoms like 14 and 16". 80 has spring trip shanks and adjustable width. Since the 60 takes less steel, fewer bolts and fewer holes I think it was cheaper than the 70 and 80 and at least these three if not the 50 were built for about the same period. There is a chance that I've not worked out that the bottoms for the 50 could be different from those for the later plows but I think the shank to frog mountings were consistent from 50 through 9000 and then 2000. Two 9/16" holes requiring plow bolts through most of the landsides.
Where plow frames and plows were ordered separately (I suspect that they didn't meet until the delivering dealer's shop), its likely these later spring trip shanks and the various landsides were also selected separately on the order. So ordering a plow probably had at least three entries, the frame, the bottoms, and the landsides, and most bottoms had 6 to 12 choices for the plow shares with different materials and shapes for different plowing conditions.
I don't see it from my parts book but its probable there was a kit of parts for the landside assembles with hardware and braces and another kit for the spring trip shanks whether bought new with the 60 plow frame or bought later and changed inthe field. This parts book does show bolt kits for these assemblies.
Landsides came with lengths from a few inches up to a couple feet. The long ones had to be braced and the only thing to brace to was the back of an extended shape of moldboard.
The differences between a 371, 372, and 373 is the moldboard. My book doesn't say what the different moldboards are like. Probably some are short and some are middle of the road and some are long like used for turning sod and in plowing contests. Some plow bottom sales brochures would explain that but I've not seen any of those. Possibly some farm magazine advertisements would have explained that too.
Gerald J.
