AgcoAllis hydraulic problem
JimF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimF Quote  Post ReplyReply Direct Link To This Post Topic: AgcoAllis hydraulic problem
    Posted: 26 Oct 2011 at 5:41pm
I have a 1993 Agco Allis 6690.  Sometimes when operating the tractor, the power steering will quit and I can't raise the 3-point; however, the front loader will work perfectly.  I can shut off the tractor and come back later and everthing works fine for a while.  At other times I can start it 2 or 3 times and I have no power steering.  Also, while operating it, it will lose the power steering and 3-point.  Help!  What can I try?
Pat SW Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat SW Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 6:45pm
I have a '95 6690 and had very similiar problems.  Transmission,hydraulics and power steering use same oil reservoir.  Bleed the hydraulic system by loosening fitting at steering cylinder and operate steering wheel back and forth to get any air bubbles out ands then tighten.  After that check oil level and fill to sight glass on rear of tractor.  Also make sure ALL hydraulic lines and fittings are tight.  Hope this helps.
JimF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimF Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2011 at 7:26pm
Thanks for the information.  I will give it a try tomorrow!
JimF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimF Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2011 at 2:37pm
Thanks, Pat, for the suggestion.  Tried it today, but it didn't work on this one.  Does anybody else have an idea?
hoffmanfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hoffmanfarms Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2019 at 12:22am
I know it has been 8 years, but what was the solution to this problem? My 6690 started doing this for the past couple of weeks.   Finally today the inside wall of the left side rear tire was covered in oil, and oil was running down behind the fuel tank near the hydraulic filters.   Something finally broke, not sure what though.   But this description is exactly what was happening to us.   (And our 6680 is in the shop.... can’t figure out why I keep running these guys...)
DaveH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 12:31pm
Same here. I've got a '95 6690 with same issue. I've been told it might be O rings goint into the hydraulic pump, but have not had a chance to check it out yet. Any advice would be welcome.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hoffmanfarms Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 1:05pm
Yes, our 1995 6690, when using the hydraulics, it leaks around the pump.  After a while the power steering stops working.  The sight glass still shows full.  If you turn it off and let it sit, power steering comes back.   Your point on the O rings actually makes sense, I just wish the pump were in a easier place to get too.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 9:01pm
Oh great. Now we have more future issues to worry about with ours!! I wish I would have been more involved in this tractors purchase with my late father. We wouldn't have bought it. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveH Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 6:45pm
What I have found is that the 6690 seems to be sensitive to low hydraulic fluid levels.  I've (I think) solved my problem by making sure the hydraulic sump is full.  I've never had any luck in seeing the fluid in the sight glass, so what I do is to remove the sight glass and fill the sump until the hydraulic fluid runs out of the sight glass hole.  Another thing to check is to make sure the hydraulic lever closest to the seat return to the neutral position -- if left in either detent position the hydraulics will freeze up after awhile.  Similarly if you try to run with the front end loader fully raised.  I think what happens in each of these conditions is that the hydraulic sump is depleted of fluid, the fluid cavitates in the pump, which causes the pump to lose prime and lock up.  So, to summarize, (1) keep the hydraulic sump level to the point the fluid flows out of the hole where the sight glass is located, (2) make sure the hydraulic lever closest to the seat returns to the neutral position, and (3) don't run with hydraulic rams fully extended.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 9:34pm
I have always had a hard time seeing that sight glass also. Several times I found a small hill and parked the tractor with the front downhill so I wouldn't lose any fluid and unscrewed it and wiped it off to remove any film. Also using a light helps atleast with my eyes. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveH Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2019 at 10:15pm
One other thing to check if oil is leaking around the oil filter.  Make sure that when you removed the old oil filter, the sealing gasket from the old filter was not inadvertantly left on the engine.  Then, when installing the new filter, you end up having two gaskets.  I've never done this on a tractor, but did once on a car.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 10:29am
We sold about a hundred of these, after time the large rubber seals on the system leak - and suck air.  One solution - remove the LH wheel and reseal about 10 items - 72230620 find that part on agcopartsbooks.com and order those oring seals  72230623 support gaskets and orings and replace those and you will be healed - loosen the power steering hose to bleed both pumps. ..
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 12:03am
Derrick, did you get your problem solved?
I don't think we have met but probably walked by each other at an auction or the farm show.
Allis Express participant
