1951 WD / GA engine designation?
Pa.Pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Topic: 1951 WD / GA engine designation?
    Posted: 23 Oct 2011 at 4:56pm
I was tearing apart a WD engine out of a parts tractor today and noticed the engine serial number had a GA designation on the end. Can anyone tell me what the GA means?
I know PA is gas and I've read that KA is distallate fuel, but I have no Idea on the GA.
Thanks,
Pete
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 6:49pm
One book says GA is gas at 5.5:1 ratio and G is the same designation after engine # W101809 which would mean that block is from a WC?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 7:12pm
What is the full serial # on your block?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 7:55pm
I don't remember it completely but it was WD 279xxx GA, so I think that would put it in early 1951. I seem to remember reading they used a couple different compression ratios, where did you get your info? Do you know what the ratio is for the PA engine?
Thanks LonnIe,
Pete
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 8:04pm
That would make it around 1951. The book I have is Original Allis Chalmers by Fay and Kraushaar. I haven't found any other places with the suffix listed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 8:06pm
That book just says high compression gasoline on the PA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 8:13pm
So is the PA higher comp. Than the GA?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2011 at 8:20pm
That book says KA=Kerosene and PA=high compression gas and that's the only 2 options for a WD. It doesn't give a ratio for PA so not sure if it's higher than GA or not? On the WC engines the Kero is 4.2:1 and all the gassers are 5:1 or 5.5:1.  No idea if the book is correct or not.
This page was generated in 0.555 seconds.
