Plow bolts
Bryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Quote  Post ReplyReply Direct Link To This Post Topic: Plow bolts
    Posted: 20 Oct 2011 at 9:24pm
Where's the best place to find plow bolts for the Allis chalmers plow shares? Thanks, Bryan
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 9:41pm
   Agco dealer has them. Be nice if there was an aftermarket source.
http://www.rumelyallis.com
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 10:29pm
This may sound dumb, but what is different about the AC plow bolts?? Ive replaced the shares on my AC plow and got the bolts from TSC. They worked just fine, and are still in use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 11:11pm
   The AC plow bolts have a head that looks like a cat's eye. Your TSC has these, Dan ?
Edited by Rfdeere - 20 Oct 2011 at 11:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2011 at 11:36pm
Are you talking about the clipped head bolts? They are more of an oval shape head than the traditional round.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 12:31am
our TSC has them!
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 12:37am
Look up plow bolts at McMaster-Carr www.mcmaster.com also Shoup www.shoupparts.com and Sloan Express www.sloanex.com
Gerald J.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 4:59am
Realy?? After scoring some NOS shares I asked my dealer about the special bolts required for the A-C shares and he laughed at me?
I ended up trying the flat headed bolts from TSC, not the clipped head but the ones that look like flat headed carraige bolts. They are softer than the shares and I just snugged them, smacked them with a  2 lb hammer, snugged again and ground the tops down flush, took less time than typing this one finger style.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 9:05am
I looked up the three suggestions above from Gerald. All the pics look the same except one, and none are listed for AC. The only one that looks different is the following link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 12:32pm
   Well AGCO had them 2 or 3 years ago, bought a bag full so have not bought any since. Figures they would stop carrying them.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 4:04pm
the bolts for the original Bullet Blade shares were unique to Allis. They had a flat head with an oval-shaped or "cat's eye" shoulder as Rfdeere called them, instead of a square shoulder like ordinary plow bolts. They are NOT clipped head, just the shoulder underneath the head is oval shaped. I got some with a set of NOS shares I bought for my plow. If there is an aftermarket replacement for the original shares, which is unlikely, they would use standard plow bolts. You will have to hunt them down at an AGCO dealer there should be some NOS around. D-allis Iowa bought my plow maybe he will be kind enough to take one off and post a picture?
Edited by Bill_MN - 21 Oct 2011 at 4:09pm
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 4:26pm
If tou get in a bind as i did just nock out old bolt run a bead around it in new share and grind down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 4:45pm
   Here are some pics of the bolt:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 9:48pm
Ive seen those bolts before, no my TSC doesnt carry those. Are they for the older plows? On my 387 bottoms they used the basic plow bolt with the square.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 11:46pm
yes, they are generally for 370 and earlier series bottoms, but only for genuine Allis "Bullet Blade" shares. the shares that were on my plow when I got it were an older aftermarket brand and used square shoulder bolts
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 7:10am
I wonder if a guy could take standard plow bolts and grind the oval shape to them, anyone ever tried this ?
oldironguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 5:09pm
Fastanal has 186 different sizes/kinds of plow bolts.  You can order online at http://www.fastenal.com/web/search/products/plow-bolts/_/N-gj4wbd&in_dim_search=1#sf for delivery to your home or save a few bucks by having them drop shipped to your local fastanal store. Takes a couple of days. They also carry 344 varieties of square headed bolts and 77 different square nuts.  Works for me!
Dick
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 8:55pm
they look like you could buy carriage bolts and grind the head to the shape to suit the hole. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2011 at 9:06pm
Dick
   They only have 6 diffrent head styles in their plow bolts though, and none of them match the Allis design.
