farmall m tractor
paul s. mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paul s. mn Quote  Post ReplyReply Direct Link To This Post Topic: farmall m tractor
    Posted: 12 Oct 2011 at 7:02pm
where can i find the hydrauolic pressure fo a 1949 farmall m tractor?
kffischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 10:34pm
A stock M with the Lift-all system will have 3 places to get pressure from. all are plumbed to the same source.  On the left side of the clutch housing, there will be two 1/2" pipe fittings and on the right there will be one 1/2" pipe fittings.  Pressure is 500-900 psi, one way, and available only with clutch engaged.
plenty of info online and on other forums specific to IH.
karl f
