wd 45 |
Freddie
Joined: 11 Oct 2011 Location: Worthington,MN Points: 4 |
Topic: wd 45Posted: 11 Oct 2011 at 9:41pm |
Low oil pressure on 45. Someone told me that the right oil filter could help. I just bought the 45, so i don't know to much about it. thank you.
Jim Hancock
Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1112 |
Posted: 11 Oct 2011 at 9:48pm |
A Fram C159 is one of the oil filters that you can use.
Tedin NE-OH
Posted: 11 Oct 2011 at 9:53pm |
Oil pressure may be as low as 12psi and still be ok
Brian G. NY
Posted: 12 Oct 2011 at 4:42pm |
12 PSI is normal pressure according to the manual.
They will run for years on a lot less pressure than that.
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 12 Oct 2011 at 6:08pm |
The pleated paper filters are bad, the rag and waste filled filters are the good ones.
Gerald J. |
wdforty5
Posted: 12 Oct 2011 at 8:24pm |
My Neighbor is in his 70's and has had several wd45's. He always says if theres any oil pressure at oil its ok, and theyll run for years.
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 12 Oct 2011 at 8:52pm |
Some people replace the factory oil pressure gauge with a 0-60 gauge. That don't work. You need a 0-30 at most to be able to see the needle move with a warmed up engine. |
stray
Joined: 16 Aug 2011 Location: Tipton, Missour Points: 323 |
Posted: 12 Oct 2011 at 9:47pm |
Did the WD45 have the oil pressure regulator on the end of the cam shaft like the D14 or D15?
1969 190XT series 3
DrAllis
Posted: 13 Oct 2011 at 6:17am |
No.
