Pacer Monitor question
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: Pacer Monitor question
    Posted: 11 Oct 2011 at 9:50am
How do I check to see if the Pacer monitor pads are working right? Will taking a handful of corn and pouring on the pads tell me enough or is there a better way? Had the shaker bushings go bad for some reason (they looked to be new when I bought this combine last year) and shook one sensor pad enough to lose the plastic fingers.
Wink
I am a Russian Bot
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2011 at 10:22pm
Be sure to check the timing on the shoe ecentrics.....that is to say,be sure there's not a sheared key or twisted shaft.I'll bet you know that already.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 5:40am
Thanks. Everything seems in time. I'm hoping the bushings were installed wrong meaning that the shoe wasn't at it's mid point when the bushings were put in. I only had 3 rounds left of beans when I discovered what was happening. One thing with the old E was that you could hear everything going on while the L2 is very quiet comparably.
Wink
I am a Russian Bot
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 8:56am
I think you can test them by having someone tap them with a pen or pencil and watch the needle in the cab.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
monitordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monitordoc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 4:59pm
 the pads for the pacer monitors are really just microphones. have someone watch the monitor in the cab while you tap on the pads. set the monitor to most sensitivety so light tapping will show.
WD,D17-S4,180,D21
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 7:54am
Thanks guys.
Wink
I am a Russian Bot
