7000 rpm surges |
Tony Elo
Joined: 13 Sep 2009 Location: guelph ontario Points: 256 |
Topic: 7000 rpm surgesPosted: 08 Oct 2011 at 3:13pm |
I have a 7000 maroon belly,the rpm is going crazy at idle sometime.It revs up and down on its own,it even stalled itself once.I read a past post and somebody mentioned something about rubber O rings in the injector pump govenor,is this a costly job if I take the pump off myself?Thanks Tony
XT in pa
Joined: 21 Apr 2011 Location: hickory pa Points: 711 |
Posted: 08 Oct 2011 at 6:20pm |
im not sure bout the o-rings but i kno our 301ci surges when the fuel filter needs changed maybe this will help ya.
Shawn
190XT,D17and 7045
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5114 |
Posted: 08 Oct 2011 at 8:06pm |
If your thinking governor flex ring, your DM doesn't use that setup. Odds are air is entering the fuel system at the pump inlet or hand primer.
MACK
Posted: 08 Oct 2011 at 10:12pm |
If it still has the small plastic line coming from top of tank to pump. replace it with one coming from bottom of tank to pump. May also need gov. linkage cleaned in pump. MACK
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 09 Oct 2011 at 12:31am |
same with my 7010, like xt said!
