amp gauge drawing battery down?
mjbower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Topic: amp gauge drawing battery down?
    Posted: 02 Oct 2011 at 12:54pm
Is it possible that the amp in our 190xt is drawing battery down. is it possible the gauge is shorted out inside checked it with a meter and that is what it seems like to me.anybody had this problem before.i unhooked the battery and put my meter in between the battery cable and the positive of the battery and unhook the key and light switch and the wire to the alternator.it still reads 12 volts of draw unhook power wire to the gauge then i have 4 volts of draw take the gauge right out of the dash not letting it touch a ground and i have 4 volts of draw sounds like to me the gauge is shorted out.any other ideas? thamks for any other info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 12:59pm
OK your meeter is reading volts or amp draw ?
The meeter on the tractor is a shunt that measures amps passing theough the shunt to move the pointer. If it is shorted out then if you take your meeter and use ohm setting from post to case and you get a reading its shorted . If open then its OK.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 9:43pm
It is possible for the ammeter to short to ground. Normally its circuit is completely insulated from ground. A good check is to disconnect both leads and hook a test light between the battery lead and either ammeter post. If the light lights, its leaking to ground. If you do that test with a volt meter instead of a lamp it may so sensitive that the ordinary gathering of dirt will make the volt meter read full battery voltage though the leakage current may be only microamps because it can take only 50 microamps to move an analog meter to full scale (like a Simpson or Triplett).
Gerald J.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 4:53am
I had this condition on a D-17. Found the problem with a test lamp.
Changed the amp meter and no more battery problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 6:20am
Over time, moisture in the air breaks down the original fibre insulators around the ammeters posts.Small growths called 'dendrites' form ,allowing current to pass to ground via the mounting hardware.When I rebuilt the '53 G electrical panel, I used brand new nylon 'shoulderd washers' from a newer ammeter, painted the steel mounting bracket at the same time to prevent rust from forming and added a itty,bitty amount of light oil to the threads of the ammeter studs.
Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2011 at 8:00pm
thanks guys its the amp gauge its shorted internally thanks again for all the responces
