Off Topic-Off Color--Ford 4000 Row Crop
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Topic: Off Topic-Off Color--Ford 4000 Row Crop
    Posted: 25 Sep 2011 at 12:25pm
I honestly can't explain why!  I purchased this for the 13.6x38 rear tires/PS wheels to use on another, a "On Topic D15 II Diesel, High Clearance, Single Front Wheel",  taking up space in my shop with no rears.
Sooo, I bought this Ford 4000, 3 cylinder gas, it has like PS wheels, i.e., holes in rails are drilled parallel to axle, also no rust holes or destroyed rims, just need painting as usual, but no flat top fenders or 3-point, PO or ? removed. The sheet metal is pretty good.
It is a Select-O-Speed, which must be a good set up or JD would not have used it.  Some say they are the same type operation.
I need some expertise on this on how to check it without engine, if possible, which is locked!
I mainly want to check the SOS before going very far with this, and who knows, it might actually be worth something.
I just don't want to have another piece of off color hardware laying around, saving it, and cluttering up the place.
I have found that the 4000 Row Crop is somewhat of a rare bird,  lots of 4000's but tall Row Crop model's are scarce.
Any help appreciated, honest.
Edited by JoeO(CMO) - 26 Sep 2011 at 8:59pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2011 at 1:34pm
Ford's SOS does not have a great reputation. There are a few mechanics with magic touch that can keep it working. Ford's chief engineer quit them because he didn't consider it ready for production but upper management put it out anyway. He hired on at Deere for the new generation tractors and made Deere's Power Shift very tough. It rarely breaks. The Ford SOS some say always breaks.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2011 at 3:19pm
There are TWO Ford 4000 tractors......the first was a four cylinder version which is just an older 900 rebadged as the new 4000 (to go along with the new 6000 Commado they came out with) and the true "new" 4000 with was only blue in color and had the 3-cylinder engines. The new is a whole different tractor that the old 900/4000. If it is the later model one, the trans would be better than the old one. We always called them Select-A-Jerk tranny's.
Roger Nolin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Nolin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2011 at 3:58pm
neighbor had a ford with selectospeed, don't rememvber which model. But I do remember that some of the gears let the tractor coast if not pulling. I went down some hills faster than I should have. if you get it running be careful.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2011 at 4:45pm
Joe: I have a guy that is supposed to be good with the sos trany here locally, give me a call if you are interested in his name and no.  Dave.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2011 at 8:44pm
The transmission is a Select O Speed.
You did not state which 4000 it was.
Only the early 801/801 series tractors had the overrun clutch whish would freewheel in certain gears. The later 801/901's and the 4 cylinder 4000's had a direct drive clutch.
The Ford tractors had 28 and not 38 inch tires.
The 1965 and later 4000's were differant.
As far as testing, there is no way without a running engine. In fact the output shaft is locked if the input is not turning.
I have a 4000 4 cylinder row crop diesel with a select o speed. I has been a very reliable transmission for over 20 years. It is a great baling tractor.
Most problems with the SOS is not keeping the fluid clean. Th valves will stick and it will not operate.
There is a learning curve when operating one. You do get a sore neck until you develop the skill.
There is a guy on YTMAG.com who is an expert on the SOS.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 8:40pm
I thought a pic would help,  ser # shows it to be
a 1967 year model
Edited by JoeO(CMO) - 26 Sep 2011 at 8:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2011 at 8:53pm
That's the newer version with the three cylinder engine.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 12:29am
I've had pretty good luck with SOS transmissions.  Probably had a half dozen over the years.  Rebuilt at least one.  Unless they were abused, and the oil not changed regularly, as stated above, they hold up well and as also mentioned, make a great baling tractor.  I currently have one of the first 300 6000's built which was recalled and completely rebuilt at the factory and repainted blue (the first 300 were red).
The SOS came out on smaller tractors, 600 to 900 series starting in 1957, I believe.  There were some problems with the early models, mostly oil leaks.  The oil hit the fan, so to speak, with the 6000.  The transmission wasn't up to the task of working with a 60 plus HP engine.  The chief engineer at Ford Tractor, the story goes, told management the tractor wasn't ready to ship until some bugs were solved.  He went on vacation and the tractors were shipped.  Problems started immediately and Ford recalled those first 300 that hadn't been improved.  It cost them a bunch of $, not to mention getting a bad rep. The engineer did quit and go to JD and improved? the SOS by making it an eight speed.
I think the SOS is a better transmission then the IH hydro, but to each their own.
Allis Express participant
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 7:56pm
There was a diesel version of that on my uncle's farm when I was a teenager.  With the flat top fenders it made a really nice looking tractor.  General wisdom is that the 3 cyl. was a much better in the diesel version than gasoline.  The clutch with the SOS was called an "inching pedal"  -- the ten "gears" on the SOS were grouped into 3 or 4 bands on the control - I was told to depress the inching pedal when shifting between bands, but that you didn't need to touch it when shifting bettween "gears" in the same band.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2011 at 8:03pm
That was a distinct difference between it and a Deere...Ford used bands in some gear selections (that required adjustment occasionally) and Deere did not. Deere also never free-wheeled in any gears.
