C Compression Pressure
Barry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barry Quote  Post ReplyReply Direct Link To This Post Topic: C Compression Pressure
    Posted: 16 Nov 2009 at 6:27am
I'm restoring a C that was running Ok.  I decided to check compression pressure before going to far.  I got 82, 74, 75, 66 dry, and 85, 85, 90, 76 after a shot of oil in the cylinders.  Should I tear it down, or is this OK for a tractor to be used mainly for pulling hay rides and parades?  Should I take the head off and redo the valves and guides? It didn't smoke noticably at idle.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 6:43am
Yor compression is on the very low end.
Sounds like we will know what you will be doing this winter.
If it runs good enough for what you are using it for then it is up to you when or if you want to tear it down for a rebuild.
The engine is ready for some work.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 3:36pm
If it is not using a bunch of oil and starts right up and as you say runs ok then I would use it the way it is until you see a change that seems like a problem.
You might find that after several hours of hard work that the pressures would even out more. Bad guides will smoke on start up and unless they are really wore bad will stop smoking or almost stop then when you start it up after a spell will smoke bad on the start up.
A small amount of oil in the cylinders would seal sticky rings to bring up you pressure readings but would not bring up pressure for a leaky valve.
A good place to try Seafoam. half a can in a couple gallons of gas in the tank and the other half in the crankcase. [as stated on the can]
Z Max is good also but costs a bunch more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barry Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 5:52pm
Guess I have a split decision.  I'm guessing that it hasn't been running much for the last few years. I bought it a year ago, and the fellow I got it from had bought it at an auction.  So, maybe the rings are sticky. Oil was pretty milky.  I'm now thinking I'll pull the head and have the valves reseated.  Probably will remove the pistons and check rings at the same time.  Any guidelines on how much cylinder wear is acceptable?  Also, I noticed the bearing cap and crank main shims are still in place.  Bet this engine has never been torn down.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 7:18pm
it will probably get better  i would run it a year then decide  it was made to run not sit
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 7:22pm
The compression on my CA that has been overhauled once without much use is right around 125psi. If it were mine, there is no question that I would be overhauling it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2009 at 10:05am
A true restoration is in fact the disassembling the tractor complete, inspecting, measuring and reassembling to same as new specs.
If you were planning to do a restoration then I do not understand the original question.
Go for it and post lots of pictures. I love to see work in process as many others do as well.
This page was generated in 0.115 seconds.
