Tractor tire
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: Tractor tire
    Posted: 20 Sep 2011 at 11:39am
I have a tire that has a hole in the side wall the size of a quarter maybe. The tire is almost new and with lots of years togo in it. Can you put a patch on the inside wall to cover the hole and run a tube in the rim? Its is on a allis c.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 12:09pm
I had a 13-6 24 Friestone where you could see the tube between the lugs. I had a boot put in it 5 years ago and it's still going. Use the tractor near everyday. Hard. Most all tractor tires use tubes.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 12:19pm
Sure put a boot in it and pretty much forget it. That's the way we used to have to do it even when tires were less than $150per.
Dana(Iowa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dana(Iowa) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 12:25pm
AJ - It was nice meeting you this past weekend.  You must have made it home safely with the Model C.  I've seen you've been posting a lot of questions since you drug her home!  Good for you.  There is no way I could have restored my first Model C without this forum.  There is a wealth of info on here!!!  Good luck with your new project.  I'm glad it found a good home!
1957 D-14 with loader
1947 Model C (restored)
1947 Model C (unrestored) SOLD!
1972 220
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 1:08pm
Thanks dana. It was good meeting you as well. Love the tractor. Like your farm. Good luck with your SS. Hope we can meet again some day.
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 5:34pm
you can boot the hole, or you can order a section reliner from gemplers to fit over the bad place
Edited by ky wonder - 20 Sep 2011 at 5:34pm
i like old tractors of all colors
Eric NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric NY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 8:36pm
Sounds like a candidate for having someone vulcanize/section repair the injury. It would be the best solution. It would be considered a permanent repair. Check with your local farm tire dealer and he will steer you in the right direction. Eric NY
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 11:16pm
Has anyone done this with the 2 ply tires for the G?  Seems like the sidewalls split if you just look at them wrong.....
ALLIS EXPRESS!
This year:
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 9:02am
Eldon, I have never tried fixing one of those that way, but I agree the tred is great but the sidewalls are full of holes.
