Progress on the WD45
wdforty5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdforty5 Quote  Post ReplyReply Direct Link To This Post Topic: Progress on the WD45
    Posted: 19 Sep 2011 at 9:52pm
Maintenance is coming along nicely, so far got...
Oil, and filter changed.
Greased all zerks according to manual.
Changed fuel filter,cleaned out sediment bowl.
Cleaned out crankcase breather and air filter..re-oiled.
New plugs,plug wires,points,condenser,rotor and cap (set points to .020).
topped off hydaulic fluid.
Next...change the antifreeze before it gets colder.
Drain and refill hytran.
check final drive levels.
Another dumb question...Where do you check the power steering fluid?
I see the tank...do you just unscrew the cap and look down in to see the fluid at some sort of level?
Thanks!
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 10:02pm
Sounds like you're gettin'er done
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 7:54am
Good -- keeping her happy. Get that antifreeze in her -- winter is coming. Sorry, can't help with your question - don't have a WD45.
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 9:44am
I do not know what the book calls for but I fill mine to 2 inches below the top of tank. If you get it too full and work it hard it will overfow out of the cap.
