Anyone still use harvestores?
D-allis Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Topic: Anyone still use harvestores?
    Posted: 19 Sep 2011 at 9:45pm
I cannot think of anyone in our area who still uses them. The pics were taken today. I doubt if I use mine many more years. The guy helping me chop is an iron man and is cutting them down with a plasma cutter just as you would fell a tree. He took one down last week and he has 2 more to go.
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 10:29pm
We use ours for high moisture shell corn, but our unloader needs attention before we fill it again this fall.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2011 at 10:38pm
Still use mine, fill with corn in the fall and grass in the spring.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 12:34am
People around here give them away too. I always wished I had one to use. Neighbor moved in a used 20 x 60 about 5 years ago. They had a 2 that they used on his home farm and he split off on his own. 4 years ago his dad died and then 2 years ago his brother died unexpectantly. Now those 2 sit unused on the home farm.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 3:18am
they were good silos...just the unloaders sucked!
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 5:27am
there is a ton of them in use around this area by the dairy guys
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 5:32am
Have 3 use 1 . The corn units are sweet ....The forage  units suck ..unloaders are pricey too ...
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 6:41am
My brother still uses his 20 x 70 built in 1976, corn silage in the fall and haylage in the summer.
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 6:44am
The company is still in business, visited their website recently:
cih_8910 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cih_8910 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 9:22am
s
Edited by cih_8910 - 08 Sep 2012 at 9:20pm
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 12:24pm
Some farmers in this area who are out of the livestock business are using them for dry corn storage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 9:43pm
A local seed company I worked for leased a farm with a few of them.While I was unloading some silage to feed out, the bottom unloading chain broke.Farm manager was not very happy.I must have been forcing it too fast(young and dumb).He made me help the crew that came in to fix.They had a box that bolted to opening and long bolts tightened and moved boxes in to make a cave.Had to dig silage out by hand as boxes moved into problem area.Smell of that silage will stay with you for a while.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 8:10am
I have three, right now I have a sheet off my corn silage unit as I have the conveyor chain off the inboard end.  Father said it would empty the silo and I disagreed, nothing like digging out the lats 15 feet when the dome has collapsed on the unloader, not the first one I have dug out.  They are great units in their day but now they are all in need of new roofs and resealing all the sheets.  The unloaders are great pieces of equipment, just have to have regular maintenance and there needs to be some soource for parts that are reasonably priced with good quality, especially the chains, as we have gone through more aftermarket chains tht are just all the wrong metallurgy construction.  I have one for corn silage, one for haylage, and one that will be dry corn as we do not feed high moisture any more, once I get the leg put together to fill it that is.
Is that a Gehl 1540 blower you are using?  I have one and run it with my 6060.  I can fill a 20 x 80 on a tank of fuel using that tractor and blower, corn in the 25 x 80 takes almost two tanks of fuel though.
Edited by Amos - 21 Sep 2011 at 8:13am
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 5:15pm
Lots of them used around here but the big farms are getting away from upright silos. I saw some that they cut doors in and put a chute and top unloader in.
The universal answer to all questions is yes, how much do you want to spend?
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 6:04pm
When I was in the army in Mannheim Germany, several farmers had small ones.  never saw them filled.  We were in an area where they had a lot of sugar beats.  Always wondered if they used the tops of them for silage.
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2011 at 7:21pm
The furniture plant I worked for had one that we stored wood dust and chips to use for boiler fuel.  It has a Laidig unloader that had a chain on the end of the sweep auger that was a bear to repair,  if there were chips in the silo,  and of course if the chain broke the silo was always full or mostly full.   Would feed dust and chips out in the exit auger hopper by gravity and punch and gouge method until it domed over then squeeze up in there and make repair.  Not  a very pleasant job.          Tim
Chris WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 10:01pm
We had two 20x80 forage units with Harvestore Goliath unloaders, and one 20x40 grain unit with Harvestore auger unloader. We used them up until we sold our main farm in 2006, we were milking 100 cows and they worked great!  I have herd many people bash them through the years, but they are the same as a lot of things in farming, if managed properly they work fine.  The biggest trick in forage is to not skimp on short arming the unloader if the silo is empty, or if the dome caves in, if that happens it makes the unloader work very hard.  A lot of guys around here are replacing the roofs with new Stainless steel roofs Harvestore is selling.  I can also think of at least three new units to go up around me in the last year.  They are mainly building them for shelled corn.  Guys are sick of the waste of bunkers, bags, or stave silos for shelled corn.
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2011 at 10:17pm
There's a place in PA that sells or installs top unloaders in harvestores...  I just can't put my hands on that paper that I saw the ad in right now..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 10:23am
Amos, have you tried using chains and sprockets  from Equipment Service?
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 10:47am
A few harvestores in use around here. Most use concrete top unload silos. The blower/unloader for them is pretty pricy also but easier to get to. Nothing better than climbing  two or three or four  times a morning when the bull wheel burries or the silage frreezes to the walls.... great feed though.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 12:04pm
Kevin. no I have not even heard of them, have you got a phone number for them?
I am always on the look out for another supplier of any of the unloader parts.  The last time I found a new place and was there picking up some chains, got to talking to the owner and when we compared notes on the changes we had made to the Goliaths, he could not believe some of mine.  By the end of a ten minute discussion he was trying to get me to work for him.  He even called me a month later and asked me to come over for a week or two to help with his back log of service calls.  Kind of makes me wonder how much people can not look at a simple device and see so many time saving changes.  Our most local fellow just shakes his head when he stops in now at some of the changes.  I even gave him some ideas for a modification he had, shouldn't have as he wants to sell me one now, just have to convice my dad I can make it and that will stop.
It is unfortunate that soem of the aftermarket chains were made with such poor metallurgy as it really turned some people off around here.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 3:39pm
I was going to hold off but couldn't resist. Our company built bottom unloading concrete silos for 25 years before I sold our farm silo business in 1995. We competed with harvestore and know all about Laidig and their parts prices etc.. Thought I'd post a few pictures from my album.
The silo that fell down was built by a Amish rebuilder out of two silos. The transition sheet was waaaay to low and it fell over in about half an hour.
The leaning silo was is southern PA. That what can happen when you don't think you need to short arm the unloader in HM corn. It finally fell over about a month later. The ironic thing is now we are working with the industrial Harvestore dealer on some water towers.
This page was generated in 0.093 seconds.
