WC starter tank?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Topic: WC starter tank?
    Posted: 13 Sep 2011 at 7:57pm
I have a replacement starter tank for my unstyled WC that I bought quite a while ago. I had a NOS cap for it but it's gone AWOL over time. But the reason I haven't put it on before now is I need a shut off valve, and to know how the line was run. The shut off on the main tank has a plug opposite from where the fuel line fitting is, was that for the starter tank line?
Can anyone tell me where to look for a shut off valve?
Edited by Dave in il - 13 Sep 2011 at 7:58pm
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 9:10pm
Mine has a Zenith carburator and there is a fitting on the front for the starter tank line.   The connection for the main tank is on the back side.   As for the valve I don't know.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 5:12am
Our 38WC  is set up the same way as yours under the main tank but also has the carburetor inlet fitting as posted by JW.  The WCs I have seem plumbed at shows went from the tank to the carb as JW suggests. Hard to tell how things have been messed with over the years but I always wondered why the extra fitting under the main tank, it does look factory??  There are several sources for that cap, I am sure Norm Mienert has them. It seems that every swap meet I go to there is somebody with a box of NOS caps, have even seen boxes of the soldered on part that the cap crews on to NOS.
Edited by Butch(OH) - 14 Sep 2011 at 5:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 9:15am
Just a thought, the extra connection at the sediment bowl on the fuel tank may have started with the 34 WC's. Many had a hood from earlier production Waukeshaw's with the starter tank on the right rear of the hood. Instead of running 2 lines to the carb, they may have connected the 2 supplies in front of the sediment bowl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 9:20am
,, so I have a gen-you-eye-n walkeeshaw WC type sediment bowl eh?
 I better get that on Ebay pronto.
Mystery solved, thanks Charlie
Edited by Butch(OH) - 14 Sep 2011 at 9:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2011 at 9:56pm
Finished mounting the starting tank.
It had a plug in the carb.
I'm not happy with this 1/4 turn valve but I couldn't find a better one locally and the Ace Hardware guy swears this is ok for fuel.
I needed an 18" line, of course I could only get a 12" or a 20", so I had to do some creative bending to deal with the excess. An 18" line would have had one 90% radius bend. I still have to take the tank off and paint it and I'm going to use thread sealer on the valve and fittings in the bottom of the tank.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2011 at 10:41pm
The cap is around. I got one from a JD90 skidloader. Oliver used them as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2011 at 10:46pm
Yes, I got a cap you can see it in the picture.
Thanks.
