Front Wheel Weight Bolt Info needed
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Topic: Front Wheel Weight Bolt Info needed
    Posted: 09 Sep 2011 at 8:33am
I am looking for sizing (diameter x length) of the bolts used to hold the front wheel doughnut weights on a D series tractor.  If I remember correctly I can just  take a carriage bolt and grind one of the (4) sides down flat?  Thank you for the help.
Mike
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2011 at 9:36am
I just did the same, I used 1/2" by 3 1/2" bolts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2011 at 10:37am
Thanks a bunch Matt.  I was going to hook up the brush mower tonight and it always makes the front end a bit light on the hills.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2011 at 8:00pm
The J bolts used to assemble Jamesway leverlock cow stantions work very well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2011 at 4:09pm
Thanks again Matt for the help.  As a follow up for anybody who searches this for future reference, perhaps I have different rims, but I ended up using 1/2" x 4" carriage bolts  as I could not get a nut started on the shorter bolts with a washer and lock washer on.
Ted,  I am not sure what brand of stalls are sitting empty in the barn but I am going to have to check now.  Good to hear from you.  Mike
Edited by Michael (WI) - 12 Sep 2011 at 4:12pm
This page was generated in 0.115 seconds.
