d17 gas tank questions
Mid-GA Outdoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mid-GA Outdoor Quote  Post ReplyReply Direct Link To This Post Topic: d17 gas tank questions
    Posted: 01 Sep 2011 at 8:57pm
ok i do tractor work and have a job that i dont think my ford 1510 can run the 5ft mower for b/e its thick grass. how much fuel (GAS) does the d17 burn in 8 hours? how big is the tank. also i have a leak around the gage. can i just take it out and put some RTV around it and put it back? thanks much
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 9:11pm
4.5 gallon max fuel use per hour.  Tank holds 19 gallons.  RTV is a band-aid, you will need to replace the gasket for a long term fix.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 9:13pm
The harder you work the tractor, the more it is going to drink.  I think the tank is close to 20 gallons, but do not know the real number.
AGCO sells the gasket for the gas guage - no RTV needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mid-GA Outdoor Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 9:21pm
holy sh!t, whats the tracor worth at fair condition and doesnt smoke. starts and runs every time.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 9:24pm
A decent 17 running in street clothes that is a series 1 2 or 3 should bring about 3 grand depenging on tinwork and gear jumping.  A series 4, no telling, they go crazy from 3 to 6 grand.
Still in use:
skip(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skip(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 10:24pm
don't bother w/ RTV. i did that and now i have chunks of orange flecks in the sediment bowl.
tank capacity is either 19 or 21. whatever it is, our old car was the other....i guess i'm getting old enough to get easily confused.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mid-GA Outdoor Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 10:40pm
just cant believe it gets 4 gallons to an hour.
dualquads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dualquads Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 11:28pm
Way back we used a D17 gas to pull a 4-14" moldboard plow.  It would burn close to 40 gallons in a 10 hour day.  Gas was around 45-50 cents a gallon then so ran the tractor for $20/day.
Edited by dualquads - 01 Sep 2011 at 11:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mid-GA Outdoor Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 7:20pm
my tank dowesnt seem that big tho. mines a series 1. i put in close to a gallon today and stuck a stick in it and it was about 2 onches of fuel on the stick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 10:31pm
RTV will dissolve in gas in a matter of maybe 1 minute. Just pull the gauge and run to the hardware or auto parts store and get an o ring that fits around the gauge. Where it seals to the tank it's round.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2011 at 10:46pm
19 gallon tank.
The tractor should burn a maximum of 4 gallons per hour under heavy plowing.
