AC7040 help
dualquads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dualquads Quote  Post ReplyReply Direct Link To This Post Topic: AC7040 help
    Posted: 01 Sep 2011 at 11:19am
I need to replace the cab blower motor in my 7040.  I don't have a tech manual and wonder if anyone could tell me the simplest way to remove it?  I have the roof slid back but that's as far as I got this morning, TOO HOT in the upper elevations of my shed today!  Thank you for any help with this.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 6:28pm
On my black belly 7000 you take the roof off and take off another steel plate with like 8 or so bolts and that gives you access to your heater core, evaporator, and blower motor.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 9:08pm
You will need a helper to hold the bolts from bottom side. You will need to remove the air deflectors to get to bottom bolts.
  There is a strip of metal about 1" wide that will keep the fans from coming out, a hack saw on one will solve that problem.   MACK
This page was generated in 0.067 seconds.
