Whats a 4 bottom SC plow worth?
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: Whats a 4 bottom SC plow worth?
    Posted: 24 Aug 2011 at 8:47pm
Was told about a 4 bottom SC plow, made for the D-19 that might be for sale locally.
Been looking for one around here for the past few years.
This one is said to have been kept inside since new, except the last 3 years the owner pulled it outside. Sounds like he pulled it new with his D-19 gas, so I am guessin it has a hydraulic tailwheel. Have no idea what the model number would be.
Anyone know what its worth? Sounds like its in great working shape.
Is it worth $400 bucks?
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 8:57pm
Condition of the bottoms is everything.  If it is greased, or just surface rusty with no pits, $400-$500, and down from there depending on condition.  Look at landslides and shares too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 9:00pm
Thanks Ted!
You use your 45 diesel with the 4 bottom last fall or this spring? How'd she do?
Galatians 5:22-24
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 9:11am
Around here $100/bottom is the "rule of thumb" for old plows.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 8:17pm
,Used to to be $50 per bottom-mostly 50/60 series,  70, 9000 and 2000 plows are around $100 per bottom depending on whos at the sale.  Lately ya gotta fight the iron man off.  I passed on a couple on 50 series plows in June,  they were missing the snap coupler eye and a couple of other parts, they went over $100, they went to China, sorry.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 5:47am
With the plow new with a D-19 it will likely be a 74 or if it has trip bottoms it will be an 84. A 2 furrow pin hitch CA plow with ACE bottoms, skimmers and cover boards in nice condition sold for $400 last week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2011 at 7:23am
Skip - even if iron is 200/ton I don't see how a even a 3 bottom 50 series plow gets bought by the scrap man for over $100 and he makes a profit for the effort...didn't think they weighed over 1000 lbs....
Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2011 at 3:12am
Scrap was up to around $305 dollars a ton here awhile back, down a little now.
1955 WD-45 with factory PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 1:38pm
Just looked at this plow, it is a model 84 with trip bottoms.
New points included, 2 of the coulters had been replaced with an off brand, needs a little work.
Looks like its in average condition, some surface rust, but can still read the "allis chalmers" decal really easy.
Owner wants $550. Still worth it?
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 9:47pm
You wont find one like that very often.Better jump.I gave 400 for my SC steering tail wheel 4bttm in early 80's. Unless the bottoms or shins are wore through the hard surface that is not excessive.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 9:55pm
   Is it fully mounted or semi-mount ? If semi is it the steerable version ? I would offer him $400 cash and go from there.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 5:17am
Its a SC mount, just the eye and two lift arms.
No steerable tailwheel, just a landside depth adjustment wheel.
Main frame of the plow, is like 6" hollow square tubing.
Galatians 5:22-24
