G Electrical Problem
oldironguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Topic: G Electrical Problem
    Posted: 24 Aug 2011 at 6:22pm
 One of my Gs has a well charged battery and a new starter switch yet the starter will not turn over.  I think I have everything wired correctly.  Any suggestions?  I'm frustrated.  Does anyone know how to convert a G from6 to 12 volt without butchering the sheet metal to fit in an alaternator?  Does anybody make electronic ignition for the G at 6 volts or 12 volts?
Thanks.
Dick
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 6:42pm
With 6 volt you need to have very good connections, I would check those first or leave the 6 volt hooked up for ignition and hook a 12 volt up to the starter to turn it over, they aren't nearly as picky about making good contact. at least you might find out if it's in the starter or the wiring?
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 6:42pm
Bad starter? Bad connections at battery.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 7:01pm
Put a volt meter on the cable at the starter, see what it reads with the starter engaged.
Dusty
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 7:31pm
Big cables(not wimpy car cables) and good grounds are the first things to check, also be sure the starter is getting a good ground to the block. If everything is right there is no reason to convert to 12 volts
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 10:14am
The 6V system is a very simple system, BUT it needs a little attention once in a while to keep it in tip top shape. Cables were mentioned, but make sure all grounds are clean and connections are also clean. Very important! If the system has its grounds and connections are clean, I would pull the starter and have it tested and inspected. Don't forget about the Battery either. Doesn't matter if its new or not. Do a draw test on the Battery FIRST! If the power supply passes a draw test, then move on. May save you a lot of time. We offer the Pertronix electronic ignitions in 6VPG, 12VPG, & 12VNG. We also offer a wiring system kit for a 12V conversion for the G if interested. Double check your Battery, connections, & grounds first before you do a conversion. Could be a simple overlooked problem....
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 10:21am
I will throw in my  help  also, if  all of the  above fail and you do  change to 12 V.  and  your  starter  is dead.  I have   brand new  12 V. starters, bolt  right on.  $295  + $10.95 frt.
 Thanks Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 10:38am
After owning a G for a short time, I see no reason whatsoever to change to 12 volts. That engine will spin over fine with 6 volts if you don't have other problems.  If the tractor has sat for a while, pull the starter and jump it with your 6 volts. Check for mouse nests in the flywheel housing. If you have good clean connections to your battery and the starter switch is good, you probably have bad brushes or worn bearings in the starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 7:29pm
Thanks Guys.
I'll be back up at the farm next week and will follow up, especially on your suggestions.  I'm encouraged by the consistency of your responses and by your encouragement.
Dick
This page was generated in 0.328 seconds.
