Need help with 190XT fluids
John Har View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Har Quote  Post ReplyReply Direct Link To This Post Topic: Need help with 190XT fluids
    Posted: 23 Aug 2011 at 10:04pm
Help,  can someone tell me what I need to put in my 190Xt for hydraulic fluid and transmission fluid. The book says something about type A automatic transmission fluid.  I am wanting to know if there is something at tractor supply that will meet the specs for both hydraulic and tranny.
Thanks a bunch
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 11:18pm
I am pretty sure Allis said PowerFluid821 would work in the transmission/hydraulic compartments of it's tractors.  If it's like a 7000, you can use 821 (or an equivalent Universal Tractor Fluid) in the transmission/hydraulic sump and the rear end, but not the final drives.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 5:32am
You should be able to tell by looks and smell if you got type A or Dextron. If you plan on changing the entire hydraulic oil I'd use 821 or universal fluid. I wouldn't mix type A and universal fluid.
Wink
I am a Russian Bot
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 4:28pm
Use the Universal Hydraulic fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 6:22pm
it was recommended by a dealer to put Ambra 134 in my hydraulics and Permatran 821XL in the trans, so far so good for my 180.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Har Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 10:36am
Can I use Universal Hydraulic fluid in the tranny also?  I am most confused about what to put in the tranny.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 10:41am
Yes!!!
