D17 Series III Alternator brackets |
Post Reply ![]() |
jkrecek ![]() Bronze Level ![]() ![]() Joined: 31 Dec 2010 Location: cleveland Points: 10 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Aug 2011 at 1:05pm |
Im switching over my D17 Series III from a generator to alternator. Does anyone know if someone makes/sells the alternator bracket conversion. The original brackets the generator uses will not work for the alternator. I am not a good fabricator so I was just wondering if someone makes them. Thanks...Jason |
Jeff Z. NY ![]() Orange Level ![]() Joined: 11 Sep 2009 Points: 7326 |
There are universal alternator brackets being sold but most of the time you still have to redo them for your application.
http://www.alternatorparts.com/Alternator_brackets_1.htm http://store.alternatorparts.com/alternator-mounting-brackets-tractor-generator-alternator-conversion.aspx http://antique-tractor-parts.steinertractor.com/tractor/Alternator%20Bracket |
JoeO(CMO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Yes, get the alternator brackets off a 170 gas and you will be in business
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21735 |
Use lower alternator brackets from a 170-175. Cut/trim the upper gen bracket so it clears the power steering pump (which a 170-175 doesn't have). Leave cooling fan off of the alternator so it clears the power steering pump belt. You don't need the cooling fan on the alternator.
Thanks, I will try to track some down..
Post Reply ![]() |
