Removing hydraulic pump cover on D14
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Topic: Removing hydraulic pump cover on D14
    Posted: 17 Aug 2011 at 2:44pm
Hello. I am planning on changing hydraulic oil in my D14. I was thinking about removing the hydraulic pump cover and cleaning out any gunk that has settled in the bottom. Is this a pretty straightforward thing to remove and reinstall?? According to what I see, it looks like a guy needs to remove the traction booster linkage guard, then remove the traction booster linkage from the end of the drawbar spring.  It looks like you then just remove the bolts and pop the cover off. Is there anything conected inside to the traction booster lever? I know it has to actuate the valve somehow. Thats what I'm concerned about.
THanks!
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2011 at 12:43pm
Would like to know also, so will bump this up.  Herb
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2011 at 10:27pm
Anyone have experience removing theirs?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2011 at 10:54pm
I'll give it one last bump??
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2011 at 11:15pm
baverwolf, I'm surprized that no one has responed to your post, and I'm not sure I'm the right one to answer it, but I will try. I'm not real up on the D14, but according to the parts book, if you are talking about the plate that has hyd pump attached to it, there is a few linkages and other things that are attached on the inside of the case. I don't have a service manual to see how these come out.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2011 at 7:36am
You'll have to loosen one of the two nuts on the TractionBooster link rod to take the spring pressure off of it. When reassembling, just put the nuts right back where they were. When you reinstall the cover plate, make note of where the roller arm goes, as it has a pocket to fit up into on the pump control.
