175 steering leak
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: 175 steering leak
    Posted: 16 Aug 2011 at 11:30pm
My 175D started dripping oil from the top of the steering column (under the steering wheel).  I assume a seal is bad somewhere, anyone else have this problem? If I have to remove the hydro motor to fix, I guess I might as well swap in the whole unit from the parts tractor....or is the seal up by the steering wheel?
ALLIS EXPRESS!
This year:
bauerd44 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bauerd44 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 12:23am
Eldon, I don't have a leak, but I looked at the AGCO parts book and it does not show a seal up high by the steering wheel.  The seals are all in the power steering valve.  Here is the link to the pages.
Hope this will help you.   Dale
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 11:17am
Swap out the steering motor from the parts tractor,  those can be more trouble than they are worth to try and fix a leak  Eldon.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 9:44pm
Who's to say the one in the parts tractor is any better?
BrianWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianWI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2011 at 12:58pm
I had the same problem with my 175D. I removed the steering valve form the tractor
and replaced the o-rings and dust seal on the shaft end and the problem was solved.
My local Agco dealer had the seal kit in stock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2011 at 12:05am
Well it is the old procrastinating fix.....it isn't leaking now.
ALLIS EXPRESS!
This year:
