How do I make a D17 "correct" ?
bincitybandit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Topic: How do I make a D17 "correct" ?
    Posted: 14 Aug 2011 at 7:59pm
Hello, new to the forum.  I am planning on restoring a 1959 D17 that has been on the farm for 15 years or so this winter, and I have some questions on how to achieve the correct look.  Not gonna be a show tractor, but I'd like to use the correct paint, decals, etc......
As I said, it is a 1959 gas model.  Specifically I'm wondering what the proper paint is (persian #1 or #2), and what colors are the wheels supposed to be?  Also the grille.......orange, creme, white, black, what would be proper?
I've seen several variations of decals that confuse me as to which is correct for this model.  The ones that are left on the tractor now, do not have the white background and have "D17" with a circle around it on the sheet metal near the foot clutch.
This may be a dumb question, but did the gas tractors, this one in particular, ever have a tachometer?  There is not one on it now, nor does it have a blank cover.  Wondering if the cover is what is missing, or the tach.........
Would this tractor have had a white steering wheel?  Or is that just a dress up item left to  the discretion of the owner?
Lastly, could someone tell me which "series" this tractor would be?
Thanks in advance for any help.  This seems to be a great site and looking forward to learning alot about AC equipment here!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 8:01pm
Also, a picture or a link to a picture of a properly restored 1959 model would be great.............
ALLIS: B, WC, G, G, D10, D12, D14, D14(NF), D15, D17, D17(NF), D19, D21, D21
MINNEAPOLIS MOLINE: U, U, U(NF), GB
JOHN DEERE: L
FORD: 871 Select-O-Speed
CASE: 600 Combine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 8:02pm
It's supposed to be P.O. 1, grille should be what's known as a "black bar" grille all painted black. Orange centers on the wheels with silver rims.
A couple books you might find interesting are: "Allis-Chalmers Farm Equipment 1914-1985" by Norm Swinford and the other is "Original Allis-Chalmers". For the most part, Norm's book is considered to be the most authoritative on A-C farm equipment.
The tach and traction booster gauges were options that could be deleted. Occasionally you see them with "plugs" in the holes where they would have been.
Edited by Brian Jasper co. Ia - 14 Aug 2011 at 8:14pm
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 8:42pm
I don't know whose tractor this is, but it is a black bar D-17.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 8:53pm
Thanks for the pic.........
Unfortunately, I must have a grille from a later model as it doesn't have the black bars.  I guess it will have to do, because it took me quite some time to find it.
Can anybody speak to the correct decals?  As I said, the ones on that tractor in the pic don't match mine.  Other than the grille and decals, it looks just like my tractor.
Is the air cleaner stack supposed to be orange?
JOHN DEERE: L
CASE: 600 Combine
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 8:59pm
The black bar grill tractors came out in late 1959 as a new for the 60's model.
If yours is an early '59, it will not have black bars on the grill but will have the diamond screen that was originially all orange the same as the tractor. In that case the D-17 decal with the oval surround below the gas tank will be correct. P.O. #1 is the correct paint.
The serial number is needed to be sure what is originial.
I just checked the good book by Norm Swinford
Serial 16500-23363 are early '59's without the black bar grill
Serial 24001-28199 are late '59's with the black bar grills
Serial 28200-31625 were '60 models with black bar grills
Edited by Calvin Schmidt - 14 Aug 2011 at 9:18pm
BPM75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BPM75 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 9:04pm
If yours is a 59 then your tractor should look just like the one in the picture, white background, d17 emblem on lower rear panel of hood. check your serial number if it is a 59 then this is what it should look like, as far as the grill look around some more maybe you will run across one, thats somthing that can changed out pretty easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 9:10pm
The S/N is 221826
Thanks guys, for all the info.  It is greatly appreciated.
JOHN DEERE: L
CASE: 600 Combine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 9:19pm
This should be the one then...
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote BPM75 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 9:24pm
Actually with that low serial # yours would not have had the black bars its a early 59 and the decals you have would be correct for your serial #.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 9:26pm
Good deal!  It appears I have the correct grille then..........
JOHN DEERE: L
CASE: 600 Combine
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 9:27pm
Its a early 59, should look like mine. Heres a pic, not to good of one but should help some.
D-allis Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 9:31pm
I sure like the looks of the D-17's. They are such a power house for their size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 9:32pm
Wow, original paint? that is nice!! very nice!
She hooked up to the mixer?
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 9:38pm
No its been repainted, but its still has the original paint and decals underneith and yes it hooked to that mixer. Handels like a champ! Lol The old tractor sure does make it eat the hay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 5:35pm
Getting ready to reassemble this D17..............
Can somebody tell me the correct tail lights that this tractor should have?  Two round combos with the switch?  Two of the smaller bullet style red ones?  One of each?
Also trying to find the little grommets that go through the fenders for the light wires........any suggestions.
And to correct my original post, my tractor is a 1957 model...........
JOHN DEERE: L
CASE: 600 Combine
MBwcIll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 6:17pm
For fender grommets go to an auto parts store.  Look on the "help" rotating rack.  Most likely there will be blister pack with a dozen or so grommets in three sizes.  The small size will fit tail light housings, midsize will fit the top and bottom fender holes.  If not, ask for 1/2 inch at the counter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 9:15pm
I've been told that the early D17's had 2 of the large bullet style tail lights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 10:44pm
Can anybody tell me the proper placement for the following decals on said tractor................
JOHN DEERE: L
CASE: 600 Combine
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 4:26am
Originally posted by bincitybandit bincitybandit wrote:
The S/N is 221826
Too many numbers for a D17. Is that last number actually a G for gas?
D17 owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 6:50am
Them decals I dont know about the shift patern is not for a 17.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 7:15am
that shift pattern is D14/D15
Charlie
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 7:37am
And the D-10, and probably the D-12, with the 2 speed Range Transmission.
Dusty
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 8:20am
The S/N is 221826
Hey Tucker, I don't think the put a "G"  on the ends of the Seiral Numbers for Gas, only the Diesel Models had a D, but I agree it is too long.  I don't want to proclaim this as fact, but let's put it this way, in all the D17s I have seen I have never seen a G on the end.  I have probably had my hands on maybe 15 different ones of the Series I, II, or III variety, never a Series IV though.  What I actually think he is seing is the first 2 is actually part of the "7" D17 maybe
Still in use:
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 8:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 8:48am
OK, I haven't been around many D17's. People should use the whole tractor number when writing them down. D17xxxxx
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 10:11am
Sorry, when I made the orignal post I wasn't using the correct S/N, which is why I originally thought the tractor was a 1959 model.
The actual S/N of this tractor is 10336..................
JOHN DEERE: L
CASE: 600 Combine
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 8:27am
The decal that says "WARNING--Before dismounting shift into neutral, etc........" ,  Would it be correct for this model tractor to place that on the "dash" area where the throttle and traction booster levers are?  I see on my D19 that there is one like this decal in that spot...........
JOHN DEERE: L
CASE: 600 Combine
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 8:37am
Go buy yourself new wheel bolts and nuts too that are zinc coated. The nuts that hold the eccentrics on the wheel center should also be new but they are the heavy duty style so probably special order from someone like Fastenal.
Wink
I am a Russian Bot
