D17 IV NEGATIVE Ground Wiring Diagram
Allis Wanabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Wanabe Quote  Post ReplyReply Direct Link To This Post Topic: D17 IV NEGATIVE Ground Wiring Diagram
    Posted: 12 Aug 2011 at 4:03pm
Anyone have a D17 Series IV NEGATIVE ground wiring schmatic?  I have a cobbled together system with alturnator etc and need to know what is supposed to be connected to what.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2011 at 5:00pm
If you have taken it from pos ground to neg ground, swap the wires around on the ammeter, and if it's a gas, make sure the neg terminal on the coil is connected to the distributor.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2011 at 2:30am
And that's all there is to it.  Couldn't be simpler!!!  make sure the voltage regulator has been taken out-of-circuit, so you don't wind up with it pulling power or wires shorting where they shouldn't.
This page was generated in 0.289 seconds.
