916H charging system |
TGerber
Joined: 14 Sep 2009 Location: ON, Canada Points: 146 |
Topic: 916H charging systemPosted: 09 Aug 2011 at 11:33am |
I have a 916H that won't start( has new battery) on it's own, I can start it by boosting it and then it stays running fine. The amp. gauge stays on the negative side while it is running- so I am assuming the charging system is not working, what is all involved in in fixing the charging system as I understand that they don't have an alternator/generator.
Thanks |
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 09 Aug 2011 at 9:38pm |
I don't know anything about the AC 916H, but my Simplicity 7114 (14 hp version) has a generator on it with a regulator. I know some brands use a starter/generator combination with a regulator. If you go to Simpletractors.com you can get info on it. They have wiring diagrams, parts and service manuals. Bob
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 09 Aug 2011 at 9:56pm |
We talking 16hp Kohler K341? They have an alternator under the flywheel and a regulator rectifier mounted on the flywheel housing. At full throttle you should measure about 35 volts AC across the stator. The regulator has 3 terminals with a single terminal going to the battery through the ign switch.
Tedin NE-OH
Posted: 09 Aug 2011 at 10:09pm |
bad battery or coroded connections.
