WC missing
kschab92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Topic: WC missing
    Posted: 08 Aug 2011 at 9:08pm
Cant get my wc to idle right. Magneto sparks on all cylinders and I just had the carb rebuilt. I have tried to time it but I can move the magneto to its full limit and there is no change in the idle. Any help? thanks
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 9:21pm
How was it before you rebuilt the carb?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 9:33pm
It missed before too. Before I had it rebuilt it would only run on choke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 9:48pm
My 35 has a Marvel Schebler off a 47WC.  It won't idle either. I did the carb myself and I went through it again after it was completely assembled. The guy that did final assembly also went through it. He says it's cause I don't have the air cleaner hooked up and it's not the "right" carb for the engine. I beg to differ, the 201 in the 47 is the same engine as the 201 in the 35 except now I have 4.125 pistons. Does my idle jet need opened up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 9:50pm
Not meaning to hijack the post Kevin. Just thought I could bring some more thought into this subject.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 9:58pm
I have origional everything. The only thing that's sticking out in my mind is I have a high altitude serial number.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 10:10pm
Well, "missing" and running rough usually refer to two different things. When they will only run w/choke generally means there is "crud" in the fuel passages, or less common, float is hanging up, or sediment bowl is clogged, causing the engine to run way lean. Rebuilding the carb is fine, but if you didn't clean the tank and sediment bowl you are doomed to repeat the process.
Charlie, he's full of it! I wouldn't suspect jets at idle, but I think there is an idle fuel passage that may be still clogged.....it's pretty small. also didn't some of them have an idle adjust for that passage? could it be mis-adjusted?
I am still confident of this;
Wait for the Lord;
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 10:13pm
A rough running allis, can also be a weak condensor in the distributor
Edited by Orange Blood - 08 Aug 2011 at 10:13pm
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 10:18pm
All the cylinders will throw a 1/2 in spark
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2011 at 11:14pm
My 35 has a rebuilt RV4B mag with good spark. Clean tank and new sediment bowl and fuel line to carb. Mine will not clear up with choke, smooths out at high RPM though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 6:27am
Missing or running rough could mean a lot of things, from something real simple to carbon stuck under a valve, or even a valve going south. A compression check would be in order first on my list of things to do. This will establish a starting point on what's going on inside the engine. Then go from there. If the compression is within spec, it could be something easy up top. Ignition, tight valve. whatever. If the compression is down, or down in one hole, there's a good place to start looking.... HTH
Steve@B&B
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 8:06am
Spray something flammable around the manifold when it's running.  could need gaskets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 12:33pm
Mine has everything new internally. It surges when you try to idle it cause the governor catches it before it dies when trying to idle. It does run fine at high rpm.
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 1:48pm
its a mag... just to let you know.. :)
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 8:56pm
I agree with John check for vacuum leaks but please don't spray carb cleaner on your pretty paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 9:52pm
She's gettin new paint no worries
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2011 at 10:17pm
Thanks for all the help everybody! It turns out I need to replace my manifold gaskets.
This page was generated in 0.089 seconds.
