What should seal kits cost for WD45 lift cylinders
John_B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John_B Quote  Post ReplyReply Direct Link To This Post Topic: What should seal kits cost for WD45 lift cylinders
    Posted: 05 Aug 2011 at 6:28pm
Took a pair of lift cyliinders apart to rebuild them the other day. I went to a local hydraulics shop to get seals and the guy quoted me $45 a piece for a seal kit, and that he would have to order them. They are a more modern type of seal--and not the origianl felt seal. Just wondered what kind of prices others are paying for teh same parts. Does this seem reasonable? thanks.
paul s. mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paul s. mn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 7:05pm
if you are refering to the cyls. that lift the arms on the back side, the are called chevron packing , on a wd or wd45 they run about $35 to $40 dollars, just did mine this spring
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 7:24pm
Check with Baum Hydraulics, download the last section or two of their catalog. www.baumhydraulics.com
Gerald J.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 8:16pm
  made my own in the 50,s used rope pacling from plumbing shop  worked good
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2011 at 8:56pm
When I did my remote cylinder for the 45 about 6 years ago, I think I paid $8 for the vee packing. I had it ordered where I worked and they didn't add any mark up on it.
